-   -   Handheld GPS interface w/ VHF DCS (http://www.sailnet.com/forums/gear-maintenance/45773-handheld-gps-interface-w-vhf-dcs.html)
e-27 sailor 08-06-2008 04:21 PM
Are there any handheld GPSs that have a NEMA output to connect to a VHF radio with DCS?
While I primarily day sail in protected waters, I occasionally do some coastal sailing where DCS might come in handy. I currently have a Garmin GPS MAP 76, but am willing to upgrade to a newer model. My ICOM VHF is DCS capable.
sailingdog 08-06-2008 04:47 PM
The GPSMap 76 has a NMEA 0183 output which will connect to your Icom. You just need to connect the following cable:
http://www.mountguys.com/photos/RB-76-2T.jpg
BTW, click on the photo to get it for about $15. :)
Garmin does a strange thing though...the Icom DSC NMEA 0183 negative line will need to be wired to the Garmin's 12 VDC ground line for it to work properly. :) BTW, this cable will also power the Garmin GPSMap 76 if it is connected to a DC power source. IIRC, the voltage the GPSMap 76 can use ranges from 3 VDC to about 32 or 48 VDC. :)
eherlihy 08-06-2008 05:20 PM
The Garmin GPSmap 478 also has NMEA 0183 interface, and comes with the fancy cable that SD mentions above. I like that it is a GPS *AND* a usable Chartplotter. I believe that the Garmin 276C, 376C, 278, and 378 would work too... Look here for detail: Garmin. We'll Take You There.
I'm not sure if the negative line goofiness applies to these units.
CaptKermie 08-06-2008 05:38 PM
I have already done what SD recommended and it works fine with my Uniden 525 DSC radio and GPS MAP 76cs. You need an MMSI number though, in order for it to be fully functional.
sailingdog 08-06-2008 05:51 PM
Actually, it applies to all the Garmins from what I've seen. :)
However, there is absolutely no need for him to spend any more boat bucks for a new GPS unit, unless he absolutely wants to. I have the GPSMap 76 CS and think it is an excellent unit. I also have a 192C mounted as the primary chartplotter in my boat. :)
e-27 sailor 08-06-2008 09:07 PM
Thanks all for your advice & help. I'll keep my GPS MAP 76 and get the cable & try it out. And I'll get the NNMI # .
sailingdog 08-06-2008 10:16 PM
BTW, make sure the serial port is set for NMEA 0183 at 4800, 8, N, 1. If it isn't, the radio won't understand it.
4800 baud, 8 bits, No parity, and 1 stop bit for those of you who don't speak geek.
