Old 07-17-2002
dscottl is on a distinguished road
Mast movement?
I have a 36'' deck stepped aluminum mast on My Douglas 32 that appears very solid. However when at anchor and the when the wind is up above 15 - 20 knots I can see that the mast is flexing about 3"-4" fore and aft near the spreaders. I have checked the rig and everything is nice and tight, Im just wandering if this movement is normal or do I have a reason for concern.
Old 07-17-2002
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
Mast movement?
If your mast is pumping 3-4 inches, something is definitely wrong. It is the forward and aft lower shrouds that would allow the mast to pump this much. Double check to see that the rig is tensioned properly. In order of the greatest tension to the least, it is the cap shrouds, intermediates, forward lower and lastly aft lowers. Excessive back stay pressure that puts the rig under compression stress could cause pumping as well.
Secondly, check the compression post or bulkhead or what ever it is that is directly below mast mounting plate. This structural member may have rot or cracked over the years.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
