08-06-2008
Last Grumpy Old Sailor
HenryTully,
We just went through the same ordeal with our 1976 Pearson 30, Atomic 4 engine and Martec folding prop. After much experimentation (and not a little gnashing of teeth!), I determined it had to be the prop. That was the consensus here on Sailnet, too. So we had the boat hauled, had the Martec folder swapped-out for the original Michigan Wheel fixed two-blade prop, and voila`: Problem solved!
If your engine/shaft alignment is good, prop shaft runout is good, and cutlass bearing is good, I would suspect the prop.
Good luck,
Jim
s/v Abracadabra
1976 Pearson P30
