Rebedding Backstay Chainplate - SailNet Community
Blogs
Old 08-06-2008
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
I need to remove my aft chainplate for inspection/rebedding. I don't have a halyard long enough to reach the stern of the boat; what is the best way to hold the mast? I do have secondary running backstays for the staysail; will that be adequate to hold the mast while I remove the backstay and remove the chainplate? Also; is it OK to leave the jib furled onto the headstay while I remove/replace the aft chainplate?
The boat has a ~50' mast; and while I'm pretty sure that leaving the jib on the headstay and using the running-backs as support is OK; I just want to be sure there is something that I am not forgetting about before I proceed.
Old 08-06-2008
jrd22's Avatar
Courtney the Dancer
Ordinarily your lower aft shrouds will hold the stick up, running backs will be an extra measure of safety. Are you going to pull and check all the other chainplates too?
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 08-07-2008
KeelHaulin's Avatar
STARBOARD!!
Yes; except maybe the headstay which is external and looks good. I'm only able to re-bed the aft lowers because the chainplates are trapped behind interior teak walls. There are doors to inspect them for leaks but no way to get them out without cutting or otherwise removing the wall. Those will wait until I can do a proper job of making access ports to get at the bolts.
Yeah; the lowers are probably fine to hold the mast; just wanted to be double sure before I go removing the backstay.
Thanks...
Old 08-07-2008
Sea Slacker
brak is on a distinguished road
I was able to rebed my chainplates without removing them. It's a bit tedious but certainly possible - depending on how your chainplates pass through the deck.
Old 08-07-2008
camaraderie's Avatar
moderate?
Keel...you plan is fine. As an extra measure of safety I'd suggest taking your main halyard and your topping lift to stanchion bases or other strong points as far aft as they will reach.
Old 08-07-2008
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
If you halyards won't reach the stern of the boat, you could always attach a line to your stern cleats then attach that line to the halyard to better support the mast.
How much Backstay? xuraax Racing 19 04-24-2008 03:54 PM
non-insulated backstay HF antenna for metal boat jimthom Cruising & Liveaboard Forum 0 05-31-2007 05:54 AM
Islander 34 Chainplate Rebedding gentry74 Islander 1 05-04-2007 07:30 PM
Adjusting the Backstay Dan Dickison Seamanship Articles 0 08-07-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
