Old 08-06-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Hot Water
We all know that the usual method of getting hot water on a small(ish) yacht is from the engine cooling circuit and a small reservoir - but that seems to me to be a complex waste of valuable storage space given the number of times you actually need hot water when sailing.
Has anyone perfected "instantaneous" gas, electric or something else hot water systems that would be suitable for use on a small boat??
Just curious..
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 08-06-2008
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
I've seen them. I can't remember the brand but I do remember they were very expensive. A couple grand if I remember correctly. I'm sure the price will come down in time, but it will be a while before they are a few hundred bucks.
John USYacht 27 "Cora Lee"
Old 08-07-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
We install something called instahot in a lot of the retail shopping centers we build. They are about the size of a small inverter and they are mounted to the wall under the sink, then plugged into 110.
Those units are not that expensive and delivers HOT water instantly, might not be a bad idea in a small boat that is storage space challanged
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 08-07-2008
Gary1 is on a distinguished road
The only catch with instant hot water heaters is the amount of current they draw. If you've got a 30 amp AC service on your boat, the water heater will eat most of that up when it's operating. Read the fine print on amps, wattage or whatever and do the math to see what the heater will draw.
Wattage/volts=amps
Cap'n Gary
Old 08-07-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
On a boat your size, I would use a sun shower or heat it on the stove.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 08-07-2008
btrayfors will become famous soon enough btrayfors will become famous soon enough
Be very wary of the instant hot water heaters powered by propane...they can kill you! There've been a number of incidents with these. A boat is not a house, and these water heaters were intended for structures ashore (no bilge to collect the explosive propane fumes). The principal danger from these heaters seems to be carbon monoxide, and deaths have been reported due to their use in, e.g., showers.
The InstaHot's draw a LOT of current. Few boats have such power available, even if these were robust, marine appliances (which they're not).
Bill
Old 08-07-2008
RickQuann's Avatar
RickQuann is on a distinguished road
Hartley,
Instantaneous hot water heaters are okay, but not really applicable to your application. The amps or btus requirements are too great and the amount of hot water is limited.
Try Johns advice; solar shower or stovetop
Old 08-07-2008
canadianseamonkey's Avatar
Caribbean Surveyor
canadianseamonkey is on a distinguished road
There are compact propane water heaters on the market like this one:
Coleman 2300A700 Portable Water Heater: Compare Prices, View Price History and Read Reviews at NexTag
You can use the small stubby propane bottles or hook up a tank. I've never used one, but it is an alternative to what you are looking for.
Old 08-07-2008
NO....THESE ARE DANGEROUS! They are NOT intended for use on a boat.
From the Coleman literature, "Unit is to be operated outdoors only in well-ventilated areas to prevent suffocation from carbon monoxide. "
Again, be VERY WARY of propane heaters on boats.
Bill
Old 08-07-2008
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
flash gas heaters
I have had a couple of boats with flash gas heaters that were terrific. They are very common on boats in Europe and were used by Hinterhoeller as well (Nonsuch and Niagara). The biggest problem with them is that they have chimneys (4" stack) and it might be hard to retrofit one on a boat that was not designed with them in mind. On my Niagara 35 the heater was located right beside the galley sink and partly (upper part) enclosed in cabinetry with controls below.
They are gas appliances and normal precautions apply. We only turned ours on when we needed hot water; then turned it off, along with the gas solenoid. There is no need to leave one running since it only takes a few seconds to light.
Marine Tankless Water Heaters Granuaile Pacific Seacraft 4 12-18-2007 10:50 PM
Salt Water in my Isuzu engine dsbentley Gear & Maintenance 20 12-15-2007 01:22 PM
Hot water system Borvaprops Gear & Maintenance 3 10-31-2007 05:24 PM
Water tanks and a hot day, be aware!!! cjmcfall General Discussion (sailing related) 6 08-06-2007 02:37 PM
Tankless propane hot water tijel Gear & Maintenance 5 05-24-2006 07:44 PM
