Prindle Cat Rudder release problems - SailNet Community
post #1 of 2 Old 07-17-2002 Thread Starter
A couple of months ago, I purchased a Prindle 16 (sail #834). I was having problems with the rudders releasing while I was sailing.
I have since relaced all rudder hardware. My rudders don''t release as often, but they still are releasing.
Does anyone have any suggestions?
Thanks,
Mike
h2ojocke is offline
post #2 of 2 Old 07-18-2002
I have an old Prindle 18. Mine has an adjustment for the depth of engagment of the latch pin attached to the rudder before it comes down into the housing. This may be too loose. The springs you replaced, so I doubt if this is the reason. Try contacting performancecat.com/prindle.htm
Good luck.
Benesail is offline
Building a New Ruuder Armchairprotest Gear & Maintenance 16 12-06-2009 10:15 PM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Hunter Rudder Problems jfalexan Boat Review and Purchase Forum 2 08-23-2002 11:17 AM
Rudder problems on a First32s5 Enric Gear & Maintenance 6 07-21-2002 02:11 PM
cracked rudder aasault Gear & Maintenance 0 10-10-2001 03:30 PM
