Old 08-07-2008
GBurton is on a distinguished road
Sterling LPU
I need to touch up a few spots on my mast that was painted with this paint.
What is the recommended product for cleaning the area before sanding and also to remove sanding residue before priming?
Thanks for any help
Old 08-07-2008
fullkeel7 is on a distinguished road
G....I completely stripped, primed and paint a CD mast using a 2 part system. I've long hit the erase button on that one but I can tell you that if you don't follow the directions exactly the job is doomed to failure. 1st hand knowledge!
Point is, different paint manufactures have their own cleaners, primers, thinners and paints and should not be intermingled with others. So I guess you should first find the type of paint and the system you want to use and then follow their directions to the letter. If you need additional help, your chosen manufacturer usually will have a hotline and are happy to field consumer questions. Good luck with the project.
Bob
Old 08-08-2008
Cheers Bob - yeah I've been bitten before by thinking that I could shortcut the 2 part paint process
Fight Club____for Sailors Surfesq Off Topic 8375 2 Days Ago 04:16 AM
Tank volume measurement Omatako Gear & Maintenance 45 05-22-2008 12:56 AM
Awlgrip on the hull...good, bad??? jrd22 Gear & Maintenance 49 01-19-2008 02:31 PM
Message in a bottle Stede Cruising & Liveaboard Forum 65 04-15-2007 01:40 PM
Sterling Hayden Profile (About.com) NewsReader News Feeds 0 10-24-2006 11:15 AM
