Old 08-07-2008
wchevron's Avatar
Detachable member
wchevron is on a distinguished road
Inverter question
i'm debating getting a norcold ac/dc fridge for my boat. it draws .71 amps at 120v and 3.5 at 12v. if i installed a small 12v to 120v inverter, plugged the fridge into the inverter, would it run at .71 amps since it's running at 120v?
wchevron
s/v Time Flies
'78 C-30
Old 08-07-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
No.
Ohms law: Electrical & Electronics, Ohm's Law, Formulas & Equations
It's obviously using a different heater element @ 120v and 12v therefore the power consumption (wattage) is different - but the 12v heater element is still needing 42 watts of power (3.5ah x 12v). The draw would be the same, plus the power draw the inverter inherently needs (and the built in inefficiency of conversion). The 120v uses 85 watts by the way, the give away to it being two separate heaters is the resistance/ohms.
No such thing as a free lunch, or a free watt when you need it.
You are better off using the 3.5ah at 12v
Old 08-07-2008
wchevron's Avatar
Detachable member
chuckes,
thanks for dashing my hopes of stumbling on some sort of electrical breakthrough.
wchevron
s/v Time Flies
'78 C-30
Old 08-07-2008
Cruisingdad's Avatar
Best Looking Moderator
Originally Posted by wchevron View Post
chuckes,
HEHEHEHE!!
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 08-07-2008
chucklesR's Avatar
Ahem. I dashed nothing, Ohm did.
I merely pointed out that perpetual motion devices were about as unrealistic as solar stiks that get 100% efficiency, or solar powered cruising vessels that need no diesel engines.
Old 08-07-2008
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
You beat me to it chuckles, I was getting ready to post a solar stik joke.
What are you pretending not to know ?
Old 08-08-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Assuming 80% efficiency with an inverter you would be drawing about 8 amps DC.
Not sure of the exact model, but the compressor is likely a DC motor powered by an AC power supply in AC mode. Wouldn't make a lot of sense to turn DC into AC, and then AC back into DC. Thats how I power my laptop... sucks the juice like no other.
Charger, inverter and alternator question Vitesse473 Gear & Maintenance 6 12-21-2010 02:29 PM
Inverter question PBzeer Gear & Maintenance 14 12-27-2006 05:21 PM
