Old 08-08-2008
harpguitar is on a distinguished road
Necessary to shut off raw water intake?
I recently had a mechanic do some work on my Volvo MD 2b 25hp diesel raw water intake engine.
He made the statement that I should always turn off the raw water intake valve for a few seconds before turning off the engine.
My question to the group is this...does that mean that it is necessary that when I go sailing and I turn the engine on and off several times during the outing, that I must turn off the valve each and every time?
Does this make sense? Why would this be necessary.
Thank you for any info.
Sincerely,
Rick
Old 08-08-2008
wchevron's Avatar
Detachable member
wchevron is on a distinguished road
i keep my intake open the whole time i'm sailing. i only close it when i get back to the dock and that is after i turn the engine off. reading the service manual for mine, if the valve is open and you are trying to turn on the engine & it doesn't start, you can eventually flood it. he may be trying to avoid that by having you shut the valve, the engine dumps some water, then you turn it off.
wchevron
s/v Time Flies
'78 C-30
Old 08-08-2008
hellosailor's Avatar
Rick, I'm not sure what his goal is, but that simply sounds impractical WHILE you are sailing, and might need the engine "NOW NOW NOW" during the day.
Never heard anyone else recommend that, but haven't been intimate with V2b engines, either.
Old 08-08-2008
Thanks guys. I have asked others as well. The manual for the boat (a 1970's Westerly Centaur) also suggests running the engine for 15 seconds with the water intake valve closed before shutting down. I guess given common sense and practicality I will do this at the end of a sailing day. Thank you again.
Rick
Old 08-08-2008
BarryL's Avatar
BarryL is on a distinguished road
Hello,
It's a good idea to close the valve when you leave the boat.
I don't believe it is necessary to close the valve when you are
on the boat and sailing and will use the motor.
FYI, I never close the valve because on my boat it is too
difficult to reach.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 08-09-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
I had to do this on a boat to prevent flooding the engine. Indeed, when not done, engine struggled to start. Painfull procedure. Months later discovered the exhaust system was wrongly designed (hand made, waterlocker not sized to hold the return water). Once fixed, never had to do it again. It's a weird requeriment, but keep you eyes open or ask someone else to review your entire exhaust system.
Nave Rara
Beneteau Oceanis 43
Old 08-09-2008
Rockter will become famous soon enough
Harp :
I've got the Volvo MD17c, and I have never turned off the intake before stopping the motor.
What on earth for?
Old 08-09-2008
Grumpymx's Avatar
Not A Real Member
Grumpymx is on a distinguished road
If you have a plastic muffler it can melt if run for 2 minutes without raw water flow. I would think 15 seconds should not hurt anything.
"The greatest pleasure in life is doing what other people say can't be done,"
Old 08-09-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
It can. It all depends. It is my understanding (IOW: I am not authoritative on this subject) that, with certain systems, on certain boats, when the engine is shut off raw water can be siphoned from the exhaust and into the engine. This is a Very Bad thing. Closing the raw water intake a few seconds before shutting off the engine breaks the siphon and prevents this. The other thing you can do is install a raw water anti-siphon loop.
Here's a thread from a little earlier this year: raw water anti siphon/vented loop? where they're discussed. I'm sure that if you search Sailnet and Google, you'll find plenty more on the subject.
The other thing to be aware of is being careful of cranking too much with the raw water intake open. The water lift muffler requires the exhaust from a running engine to empty it. If you crank too long w/o the engine starting, the water lift muffler soon fills up, then the water backs up into the engines exhaust manifold, thence, via the exhaust valves, into the cylinders and, eventually, just about everywhere else in the engine. Very bad.
If I have to crank more than 10-15 seconds, the raw water gets shut off.
Jim
s/v Abracadabra
1976 Pearson P30
Old 08-09-2008
So it sounds like I really need to make sure I shut off the raw water intake if I have starting problems. Given all that has been said i will 1) turn off the intake for 15 sec before shutdown at the end of a sailing day and 2)I will not crank it for more than a few seconds with the intake open...I will close the valve if I am having starting problems. Fortunately this particular engine tends to start right up.
Thank you again,
Rick
No raw water flow after attempt to winterize - What happened Pamlicotraveler Gear & Maintenance 19 01-23-2008 07:13 PM
Salt Water in my Isuzu engine dsbentley Gear & Maintenance 20 12-15-2007 01:22 PM
Raw water cooling reluctance Boat Review and Purchase Forum 1 03-16-2007 04:28 PM
Beyond the Bucket Brigade Brian Hancock Seamanship Articles 0 01-01-2003 07:00 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
