Old 08-10-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
Autopilot when crazy
The other day I motor-sail solo tp an island 10 miles away to meet so,e friends for bbq and overnight. Next day as I motor back, my autopilot shows >+10deg offset from gps reading. No problem, I just set it and let it run but shortly the pilot behave crazy and started swinging the boat. I check and the pilot bearing swings all over the place. Switch it off and on again - no luck. So I continue on the journey, 1/2 hr later I put the pilot back to auto and presto! it works just fine for 1 hr then it acts up again. When this happens, I tried swinging the autopilot using the User Cal feature but it doesn't seems to help. Back at the dock the autopilot bearing looks to be normal. So what gives? I've Raymarine ST4000+ MKII Wheel with Rudder Ref Unit.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 08-10-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I'm no expert, but I would first check all the wiring related to the autopilot and make sure you're not getting a short anywhere.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 08-10-2008
Sea Slacker
brak is on a distinguished road
I'd say that this is a problem with fluxgate compass. I would check its wiring first, and also whether there are any new metal objects nearby.
Old 08-10-2008
whroeder's Avatar
whroeder is on a distinguished road
Then do the recalibrate procedure
Old 08-10-2008
Whampoa's Avatar
Whampoa is on a distinguished road
I think brak's suggestion merits looking at. Earlier this year on a trip in the Bahamas, we experienced similar behavior on a friend's catamaran after new crew members put the canned goods away. After scratching our heads for quite awhile we checked the cabinet where the flux compass is located only to find it buried under about a dozen steel canned goods. We removed the cans and didn't see the problem repeat for the rest of the trip.
I would also verify the the rudder position reference sensor is properly aligned. On our Chesapeake trip in May the autopilot on Whampoa began to act up and it would struggle to maintain a heading even in calm seas. We went over all the components carefully and found that the rudder position indicator arm was loose and had been bumped out of alignment during heavy weather. Aligning this and tightening things up resolved the problem and we continued the trip with no further problems with the autopilot.
I'm not sure how your system is set up but make sure nothing is physically interfering with the unit.
Good luck with the problem.
Regards, John
Whampoa
US East Coast
1962 40' Auxiliary Cutter
S.S. Crocker - Design # 330
Old 08-10-2008
hphoen's Avatar
"Nevis Nice"
hphoen is on a distinguished road
That happened to me, too. Motor-sailing along on autopilot, and we suddenly took an excursion.
My tool bag had made it's way across the sole and ended up next to the fluxgate compass. Moved the metal and all was OK.
I'm not saying that this was your problem, but it's something to think about.
Hud
s/y The Belle of Virginia
Island Packet 380 (now sold)
Nevis, West Indies
Old 08-10-2008
capthor is on a distinguished road
Smile The likelyhood
Most likely you have a bad connection to your FLUXGATE COMPASS or something is stoved too close to it and makes it fluctuate on the heading.
Good luck keep smiling Capt Thor
Old 08-10-2008
BTW, there are a lot of things that have strong magnets in them that you might not think of. The emergency "shake" flashlights have strong permanent magnets in them. Check to make sure that there is nothing near the fluxgate compass.
Old 08-10-2008
Thanks guys. Now what has changed, I've put a large SS pot in the galley cabinet (close to fluxgate) that didn't seems to affect the autopilot for the trip up. After trip the pot gets transferred to another boat so I doubt that's the cause as I've done the User Cal swing as mentioned. Connections - I have to check. Rudder Sensor - I have to check the mounting since it sits on a wooden puck. There has been pretty wet weather lately so the wooden puck could have been affected some. I sure hope its not the ST4000+ Display set failing. I won't be back to boat for next 2-3 weeks (on business trip), but will reverting with findings after that. Cheers.
Ken
Old 08-10-2008
hellosailor's Avatar
The wiring, the fluxgate, and also RFI: Radio frequency interference getting into the wiring from the compass to the autopilot, or into the autopilot's main board. RFI can take strange forms, for instance, any GSM Palm Treo (Tmobile, AT&T, etc.) will create audio noises on any computer or car stereo, etc. within two feet of it, sometimes once a day sometimes once an hour, as the phone communicates with the local towers--when it is NOT being used.
Any new gadgets aboard the boat? Any radios or bluetooth-equipped devices?
The last possibility would be that the autopilot itself has gone mad, and something is wrong in the brains of it. Could literally be a loose screw or a strand of wire floating around in there, or a cold solder joint that was working open and closed. It is worth opening up and eyeballing it with a magnifier, to see if any of the joints look bad. Cold solder joints plague all kinds of gear.
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Autopilot Overview Tom Wood Gear and Maintenance Articles 0 03-22-2002 07:00 PM
