ST4000 tiller autohelm wild over correction - SailNet Community
Blogs
Old 08-11-2008
hertfordnc is on a distinguished road
Subject autohelm has worked perfectly on my 1977 Nich 31.
Saturday I turned it on and it went into a slalom.
Any guesses where to start looking for trouble? I probably won't replace this anytime soon (adopting a child) and the system is dated so I will probably just look for components on ebay if I can't find something to fix (wiring?)
thanks
In over my head?
First Boat, a well-equipped 1977 Camper Nicholson 31
What is all this stuff and how does it work?
Old 08-11-2008
never mind
it looks like a lot of good answers are posted above- same problem, same autopilot, same weekend-
thanks
In over my head?
Old 08-11-2008
HerbDB's Avatar
HerbDB is on a distinguished road
You might also try resetting everything to factory defaults. Some stray electrons may have changed the response settings.
If that doesn't work, check the compass heading sensor and its wiring. Erratic heading inputs can give your the type of behavior you are experiencing.
Herb DuBois
Beneteau 36CC
Split Decision
Old 12-06-2008
autopilotos is on a distinguished road
Hello,
Check if there are no magnetic materials ,like magnets,speakers,ventilators(some swinging ventilators have shown influencating the fluxgate compass)near the compass .
Or perform new setup of the system as in the manual.
jean
Old 12-15-2008
kymatthegulf is on a distinguished road
autohelm contacts
Hello, I spent hours on my tiller helm ( autohelm200) resetting etc and it still gave up occasionally or went into slalom mode. Eventually I used "contact cleaner on all the wires and connections and opened up the case and very carefull dismantled the unit . opened the touch buttons and cleaned them, reassembled with silicone grease . wow it worked a treat. Phew saved lots but took 10 to 15 hours patient work.
Old 12-15-2008
mine "fixed itself" but looking over this thread I suspect it had to do with the contacts.
After the above replies I returned to test it and it worked fine. I can only assume the problem was in the connector in the cockpit having not done anything to any of the wiring.
In over my head?
AutoHelm ST4000 jheitzman Gear & Maintenance 4 09-27-2011 07:01 AM
Mounting tiller pilot dilemma AlbertJ Gear & Maintenance 3 10-11-2007 07:15 PM
Tiller too long? jjrux Gear & Maintenance 24 10-06-2007 01:45 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
