When do you use the 225 degree masthead light? - Page 2 - SailNet Community
post #11 of 22 Old 08-11-2008
Whampoa's Avatar
For our evening reading - A visual aid.........
Navigation Rules Online
Whampoa
US East Coast
1962 40' Auxiliary Cutter
S.S. Crocker - Design # 330
Whampoa is offline
post #12 of 22 Old 08-11-2008
Whampoa-
Not really a good visual aid, since it all words...
This page is a bit better, since it has illustrations.
sailingdog is offline
post #13 of 22 Old 08-11-2008
Whampoa's Avatar
Oh that's right, I forgot you were a Mac kinda guy ...I stand corrected
Whampoa
US East Coast
Whampoa is offline
post #14 of 22 Old 08-11-2008
[QUOTE=EO32;352842]So the purpose is to signal that you are a sailboat under power, whereas power boats only have a white stern light..../QUOTE]
Not quite! All power-driven vessels are required to show a white light forward. For vessels over 12 meters LOA, this must be a 225 degree white light, located on the centerline. For vessels under 12 meters LOA, the masthead (or steaming) light optionally may be carried as one 360 degree light (representing both the steaming light and the sternlight). Rule 21.
Power-driven dingys, by the way, are not exempted...they must carry sidelights and an all-round white light.
Bill
btrayfors is offline
post #15 of 22 Old 05-16-2009
[quote=btrayfors;352973]
Bill
?? so if my steaming light mounted to the front of my mast is out on my Pearson 26 (26'), I can use my 360 degree masthead anchor light as my steaming light (I also have the standard stern white running light)?
I thought they had to be separate/ that the 225 degree range for the masthead steaming light was a limit (ie visible only for 225 deg., not 225 deg or more)?
Jon
(also in Arlington)
S/V Catalyst:
Pearson 26 #1200
fendertweed is offline
post #16 of 22 Old 05-17-2009
mitiempo's Avatar
No you cannot use both the masthead 360 degree light and your stern light as then you would be showing two white lights from astern.
mitiempo is online now
post #17 of 22 Old 05-17-2009
Lightbulb
that realization came to me while I was asleep last night
I suppose I could do a work-around and put some Gorilla Tape over the stern light on the transom until I can fix/replace the steaming light on the mast --- (?) and then I'd have only one light showing from astern/abaft (the masthead 360) ...? ...
that would leave me, though, with the disadvantage in close quarters (the channel coming in & out for ex.) of no stern or steaming light down low where it may be more visible...
S/V Catalyst:
Pearson 26 #1200
post #18 of 22 Old 05-17-2009
jimq26's Avatar
Maybe this link will help you understand the rules.
reviewlights
jimq26 is offline
post #19 of 22 Old 05-17-2009
Originally Posted by jimq26 View Post
thanks, I am fairly familiar with the rules, just have some questions on implementing them.
...specifically, the page after the one to which you linked states the rule that prompted my question: "a power-driven vessel of less than 12 metres ... may exhibit an all-around white light and side lights."
... which is what a masthead 360 plus the front nav lights would show on a 26' sailboat if the stern white light is not on.
regards,
Jon
S/V Catalyst:
Pearson 26 #1200
post #20 of 22 Old 05-17-2009
Sabreman's Avatar
That's 39.37'. I knew that it was bigger than me, but I didn't realize that I was that close to the edge. I have a cone too but have never used it. ... But I knew what it was even if I was ignorant of the length limitation
Thanks for the post. Boasun's right, we're mostly ignorant of the Rules of the Road. My Brother-In-Law just received his 6 person license. I think that I'll quiz him.
EDIT: Sorry guys, I forgot to mention that I was referring to the steaming cone on Page one.
Sabre 38 "Victoria"
Sabreman is offline
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
