Old 08-11-2008
EO32's Avatar
EO32 is on a distinguished road
When do you use the 225 degree masthead light?
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 08-11-2008
cnbnichols is on a distinguished road
When you are motoring after sunset or during limited visibility.
Old 08-11-2008
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Yep.............
Old 08-11-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
225 degree light is properly refereed to as a steaming light. To be used while under engine power.
Old 08-11-2008
EO32's Avatar
So the purpose is to signal that you are a sailboat under power, whereas power boats only have a white stern light.
How many of you fly a black steaming cone when motor sailing?
I found one from the PO had and I thought is was a small sea anchor.
- E.B. White
Old 08-11-2008
Flying a steaming cone isn't required in inland waters for a vessel less than 12 METERS LOA in the USA IIRC.
Old 08-11-2008
timebandit's Avatar
timebandit is on a distinguished road
Do you need to run it if you have the sails down??
Rick
Old 08-11-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Rick
If it's dark/dusk or otherwise limited visibility out, YES.
Lights aren't needed at all during normal visibility/daylight hours.
Old 08-11-2008
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Flying a steaming cone isn't required in inland waters in the USA IIRC. It is required in international waters though.
Gesh! According to the Rules it is required under both International and Inland.
What has happened is that to many people have little knowledge of the rules and we support the lawyers that way.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 08-11-2008
Actually Boasun, for my boat it isn't. IIRC, the rule for the motoring dayshape only applies to boats over 12 Meters LOA. I've clarified my original post.
LEDs afloat GoodOldBoat Gear and Maintenance Articles 18 3 Hours Ago 03:15 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
