Volvo MD2B owners - need info - SailNet Community
post #1 of 7 Old 07-18-2002 Thread Starter
I''m wondering if the MD2B is still supported by Volvo and thought those currently owning one would know. Are new parts available (e.g. lower end bearings or a mechanical lift pump) or just gasket kits and such?
If you could give me a feel for how tough it is to rebuild this engine, I''d surely appreciate it. Thanks.
Jack
WHOOSH is offline
post #2 of 7 Old 07-20-2002
hi the md2b engine is still around, you can order parts from any volvo dealer, just a bit
expenseive.
Capt. niles stelly
nstelly is offline
post #3 of 7 Old 07-20-2002
Looking for a reverse gear for an md2b volvo engine with the reduction gear on the back, 1:87 reduction.
N. Stelly
nstelly is offline
post #4 of 7 Old 07-21-2002
I rebuilt my MD2B with MS reverse gear from the crankshaft to the valve covers in 1998. I looked at the guy quoting me $75/hr, looked at the manual, and did it myself. Parts are expensive, but show up fast from sweden. The manual needs to be reviewed carefully, as I found misplaced decimal points when torquing down the head to accommodate the .008 shims under the heads. You also need to disconnect the shaft if you lift the engine slightly to get at the access port on the starboard side to install new bearings on the crank (and dig the schmoo out of the crankcase). There''s a vane in the transmission that is fairly fragile which you can break if you try to shim up the engine to get the access cover plate off. When you''re figuring the number of paper shims that go under the jugs, start with 4 .008". They tell you to strap the jug with a piece of steel and torque down without the head, so you can measure the remaining space in the cylinder at TDC and measure how much of the head hangs down into the cylinder. As I recall, the difference is where I discovered a decimal point error in the manual. The bottom line is you don''t want the valves to strike the piston at TDC. It''s a simple engine, and I actually enjoyed pushing the button after the rebuild and hearing it fire in half a dozen turns. Not a big deal. KW
VIEXILE is offline
post #5 of 7 Old 08-26-2002
I have a ms reverse gear. excellent condition. recently gone through.
I recently replaced my MD2B with a FW cooled MD11D and the MS gear would''nt match up with the new engine.
San Diego, Ca
John Lyon is offline
post #6 of 7 Old 08-27-2002
Jack, if you are in St. Pete Fl. Bluewater marine can help you with just about anything you need. If you are rebuilding, brngs. gask. pistons. They can order. They are the only dealer in town. I rebuilt mine 4 years ago but I had Thompson Machine resleave the cyldrs. I even have a spare parts motor in garage.
If I can be of any help, don''t hesitate to ask.
Dave R.
windancer1 is offline
post #7 of 7 Old 09-11-2002
Hi John
sorry i haven''t checked this post lately, do you still have the gear for the MD2B.
E-mail me at nstelly@bellsouth.net
thanks
Niles
nstelly is offline
Abacos Info... BobbieP General Discussion (sailing related) 1 01-19-2005 06:23 PM
volvo md2b raw water cooled fsmith Gear & Maintenance 6 04-28-2003 11:48 AM
anybody have info about volvo md1c obiec Gear & Maintenance 2 04-10-2003 11:02 AM
Volvo Folding vs Maxprop feathering uri General Discussion (sailing related) 1 06-27-2002 08:06 PM
Volvo intake valves for MD6A not avaiable from Volvo Larrys Pal Gear & Maintenance 5 03-27-2002 06:58 AM
