08-12-2008
Detachable member
Leaking Impeller housing
i replaced the raw water impeller and gasket yesterday on my atomic 4. before replacing i noticed it was leaking near the bottom screw of the faceplate. i removed the plate and noticed the gasket was all torn and figured that was the problem. installed new impeller and new gasket. still have a leak in the same spot. the screws are fully tightened. the gasket is paper thin so when you tighten the screws i can't see it compressing the gasket to help with the leakage. do you think it would help to double up the gasket?
wchevron
s/v Time Flies
'78 C-30
