08-13-2008
the pointy end is the bow
I was on a mooring for about 15 years. During that time, I watched several mistakes being made by people around me and made several mistakes myself. I saw small boats float away large weights when their scope was too short. I saw several moorings fail because galvanized fittings were mixed with stainless steel saftey wire. I also saw several moorings fail due to rope rodes chafing through in one place or another. Another common failure is using a store bought mooring buoy and then attaching your boat to the top ring and the mooring line to the bottom ring. Those things come apart after just a year or two in the water around here.
When I considered how deep my mooring should be, I considered my draft on a minus tide on a stormy day and then gave myself a little extra just incase my keel was bouncing in the waves right over a neighbor's mooring weight or anchor sticking up from the bottom. I can't comment on the holding power of a 200 lb mushroom anchor, but around here, the moorings that seem to last the longest use a large diameter rope rather than chain, that is floated a couple feet off the anchor with a swivel. You need something to keep it all from getting wrapped up in your anchor/weight while it's settling in. Anyway, that's a start. There's a fellow here on sailnet a little further north of you that has quite a bit of experience with mushroom moorings. His handle is Halekai or something like that and you may be able to find some information by searching for a previous thread on using a train wheel for a mooring weight.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
