Raymarine' seatalk is dropping out - SailNet Community
post #1 of 9 Old 08-13-2008 Thread Starter
Brezzin's Avatar
I have a raymarine system that is periodically losing the sea talk components. The sea talk components have started to drop and then in 2 to 3 min come back on line. There is no pattern or noticeable reason for this.
I mentioned it to a buddy who is a paid captain said he believes it's the new V4.29 software update. This holds water because it started soon after the update. Has anyone else had a similar issue or have heard of issues with the new update?
Thanks
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
post #2 of 9 Old 08-14-2008
Once known as Hartley18
Classic30's Avatar
Dock
Dave, are all your devices V4.29 compatible, or is one of them still using the old version? Have you tried going back to the old version? Have you checked that the earthing connections are still okay (not loose)??
Cameron
Classic30 is offline
post #3 of 9 Old 08-14-2008 Thread Starter
Brezzin's Avatar
You see that's the issue. I have an E80 at the Nav Station and a E120 at the helm. The update was for those displays and should not have effected the seatalk items. I did a cursory look at all the connections and they look fine. But I have not dug deep into the wiring yet. That is a pretty time consuming project being the location and wire runs. If other people are experiencing the same issues then I can guess its a software issue. If not, then a hardware issue. My gut says hardware. Regarding going back to V3.3 I have it on my laptop and quickly reinstall it. I'll check whit raymarine on a procedure for that.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
post #4 of 9 Old 08-14-2008
danielgoldberg's Avatar
You can do it right from the E120 or E80. I can't remember the sequence as I write this, but you can go through the main menu and step back to the last software version. You might even be able to get instructions on how to do this on the Raymarine (or is that Praymarine; sometimes it works, sometimes it don't) website.
I'm just joking about the Praymarine thing. Some people don't like the system, but I for one really like it.
Dan Goldberg
danielgoldberg is offline
post #5 of 9 Old 08-14-2008
vagrant
bobwebster's Avatar
I've had similar problems that stemmed from a flaky wind display. It worked, but caused the seatalk to drop out occasionally. We have and E120 and two E80s. Try disconnecting the various seatalk devices on the boat to see if this fixes the problem.
bobwebster is offline
post #6 of 9 Old 08-15-2008 Thread Starter
Brezzin's Avatar
I sometimes think that Raymarine suffers from what I call the Microsoft syndrome. The are big, have a large user base and flashy marketing stuff so people tend to beat up on them. But like Microsoft the stuff usually works as advertised (Microsoft Vista excluded).
I'll see if I can't get the reinstall procedures thanks for the tip.
BTW, How was the Bermuda Rally? I can't find any write up or post rally reports. Any issues? did it meet your expectations? etc....
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
post #7 of 9 Old 08-15-2008
Windows XP SP3 has caused some serious problems ...
sailingdog is offline
post #8 of 9 Old 08-15-2008 Thread Starter
Brezzin's Avatar
That's a good idea, If reinstalling the older version works then I'm planning on doing just that. Unfortunately I have had no time. Last weekend I was in Clayton NY wreak Diving in the 1000 Islands and I leave for Bar Harbor ME tomorrow for some sort of Corp. Function.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
post #9 of 9 Old 08-17-2008
Classic30's Avatar
Dock
I'd suggest doing this before reinstalling the older version - if the system works with all-but-one slave working, then you've saved yourself a heap of bother wrestling with software.
Take a tip out of the Microsoft book and re-install the old version as a last resort.
Raymarine Autohelm ST1000 Problems And Raymarine Warranty petertribo Gear & Maintenance 9 07-27-2008 10:36 PM
Initial Impressions: Raymarine Lifetag System artbyjody Gear & Maintenance 1 06-22-2008 09:22 PM
New York-listed Garmin is mystery bidder for Raymarine marinedtcomRob Gear & Maintenance 33 05-27-2008 02:10 PM
seatalk network ? Mike244 Gear & Maintenance 9 05-21-2008 12:01 AM
Seatalk failure Mkfcdl Gear & Maintenance 2 09-20-2005 07:05 AM
