08-14-2008
It may be okay, but it depends on how well backed and mounted the stanchions are, as well as how well you're going to re-fasten and support the hull-deck join. Be aware moving the toe rail to the stanchions is going to remove a lot of strength from the hull-deck join, since it sounds like the original toe rail was being used to support and reinforce the joint.
As for Iroko, it should be fine as a replacement for the teak, but will require you to take care when working with it, since iroko wood dust is a known allergen/irritant.
