Old 08-14-2008
MiVelero's Avatar
MOI
MiVelero is on a distinguished road
Autohelm ... Help
Greetings,
I've got a Autohelm 4000 that works fine but.....
I can see a - what looks like a steel wire- protruding from the edge. Like I said the unit works fine but I know what is coming.
I assume this might be part of the belt? (like a steel belted tire when it comes appart)
I had notice lately it would be hard to free when not used for a day or so, I would turn on autopilot and engage clutch move several degrees disengage and all would be fine.
1. are there replacement belts for these and where?
2. would the MKII wheel drive work as replacement ?
And yes I've googled ....
I only found operation manual but nothing that would show parts or inside unit.
Thank you
Old 08-14-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
According to my installation manual, the 4000 and Mk II wheel drives are different. It doesn't say to what extent, only that the Mk II can be used with the new S1 unit, but that the 4000 isn't compatible.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 08-14-2008
A recent thread posted a new source for decent belts for the ST4000 IIRC. You'll probably need to do a google search for it.
Old 08-14-2008
JSL3's Avatar
<----- thinking of this
JSL3 is on a distinguished road
Thank you
Somewhere on the web I found a .pdf version of the ST4000+ Autopilot Service Manual. It has assembly/disassembly drawings for the wheel drive unit. I forget where I got it but if you PM me, I'll email it to you.
~Jim
Ramble On
1986 Pearson 28-2
Old 12-06-2008
autopilotos is on a distinguished road
Probably the wire protruding from your wheeldrive is a part of the belt wich indicates a broken belt,if it is a black autohelm 4000 for mounting on the wheel, the belt is a polyurethane
timing belt with steel core AT5-750 width 10mm
jean
TimeLock Marine Pilot 1600 - autohelm instructions wanted sord General Discussion (sailing related) 1 04-13-2010 03:07 PM
old autohelm electrical socket jimmiebuchanan Gear & Maintenance 1 02-06-2008 09:40 AM
Raymarine Autohelm & Solar Panel dougshipl Gear & Maintenance 4 10-17-2007 11:39 AM
Autohelm 6000 autopilot Rskipper Gear & Maintenance 5 09-15-2007 10:46 AM
Autohelm 4000 Booher Gear & Maintenance 4 10-15-2003 05:09 PM
