Old 08-14-2008
deniseO30's Avatar
Lies about her age
noise and water mufflers
I'm pretty happy with my universal 5416 now. But, I would like to reduce engine noise. The existing water Muffler is round, pretty small. Before I go and start adding insulation (mildew and moisture problems with that) to the engine compartment, is it wise to change to a different water muffler someday? Most engines I've seen in the same HP range seem to have larger rectangular water mufflers. (16 hp)
I may try some fiberglass duct board just to see it if helps. If so.. I'll get some "marine" sound proofing material It just seems like water mufflers that really aren't very expensive may be a simple choice. Thoughts on this anyone?
thanks in advance!
correction. "waterlift muffler" top in top out 1.5" hose. I was looking at centex's site for information also
Old 08-15-2008
Gary1 is on a distinguished road
I added a Vetus water muffler to my existing 'lift' and was satisfied with the noise reduction, FWIW.
The other thing you can think about is getting one of the baffled air intakes. I know this sounds strange, but the intake noise in the engine room is generally more obnoxious than the exhaust noise. Racor makes one, and I found it at Jamestown distributors. I think the one on the Phasor is made by Nicholson, but I'm not sure about that.
Cap'n Gary
Old 08-15-2008
deniseO30's Avatar
Lies about her age
Gary, now that you mention it.. your right the intake is very noisy!
thanks!
Old 08-15-2008
SteveInMD is on a distinguished road
I agree with the posts re the intake.
On the exhaust side, a fairly recent trend is to add a cooling water separator. The separator will help to remove the "whooshing" sound created as the cooling water surges through the exhaust system. After the cooling water has done it's job it is separated out in a device that resembles a muffler. The exhaust then exits mostly dry and the cooling water is drained off to a outlet just below the water line.
Salt Water in my Isuzu engine dsbentley Gear & Maintenance 20 12-15-2007 01:22 PM
Beyond the Bucket Brigade Brian Hancock Seamanship Articles 0 01-01-2003 07:00 PM
