08-15-2008
If you open the final low pressure side bleed point (the one where the fuel enters the high pressure injection pump), and you activate the lift pump manually, do you get a clear strong flow of fuel, or is does it have any bubbles? Make sure you open the bolt until you can see the hole on the threaded part of the bolt. If you get any bubbles you have an air leak somewhere. Even if you don't I would still check over all connections. A small air leak can be hard to find when operating the lift pump by hand.
