Old 08-15-2008
NewSailors is on a distinguished road
Transmition
Hi everyone!
I have one quick qustion.
Under sails which position should I leave transmition - Neutral, forward or backward
My boat has regular prop - not foldable
Thank you for you hints.
Old 08-15-2008
Catalina 320
jnsailing is on a distinguished road
Reverse is recommended while under sail on my boat
John N.
JN having another Senior Moment -
Catalina 320
College Point, NY
Old 08-15-2008
Karletto's Avatar
Karletto is on a distinguished road
neutral (but doesn't matter if u ask me)
Old 08-15-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
We just went thru this w/in the last week or so, didn't we? Unless your boat, engine or prop manufacturer has a different recommendation: My impression is reverse is regarded by most to be the best.
Jim
s/v Abracadabra
1976 Pearson P30
Old 08-15-2008
erps's Avatar
the pointy end is the bow
Our two previous boats with fixed props recommended locking the shaft while sailing to keep the transmission from spinning. The Catalina 34 was explicit about using reverse to do this. The explanation I heard is that the spinning components in the transmission may not get the required lubrication when spinning without the motor spinning as well. I don't know if that's true or not, but I do see that it can add hours and hours of wear to the drive train that are not necessary.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 08-15-2008
jjablonowski's Avatar
jjablonowski is on a distinguished road
What's the make and model of your transmission?
The owner's manual for the tranny on my Catalina with a Universal diesel says neutral.
Old 08-15-2008
SteveInMD is on a distinguished road
There are good arguments for any of the above, so try all three and see what you like the best. Some say a turning prop has more drag and some say it has less. I think the most common choice is reverse.
Old 08-15-2008
erps's Avatar
It was an '89 C-34. I think the motor designation was M25-XP
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 08-15-2008
Thank you guys for your good advices
I have Yanmar 2GM 1981
Old 08-15-2008
Rockter will become famous soon enough
In neutral, my old prop spins.
In reverse, it doesn't.
