Place to buy solid wood tillers - Page 3 - SailNet Community
 1Likes
post #21 of 33 Old 05-28-2010
I made a solid wood tiller out of mahogany. I hand-selected the wood, and found a plank with the grain that curved just where I needed it to curve. Using the old tiller as a pattern, I made the new tiller slightly thicker than the laminated one, to increase it's strength. IMHO, with it's added thickness, it was much stronger than the old one, looked beautiful, and had a hefty feel to it.
Finding the raw mahogany was the hard part. After that, it was a simple winter project.
Sailormon6 is offline
post #22 of 33 Old 05-28-2010
blt2ski's Avatar
A baseball bat for a tiller handle......hmmmm....... I had one made into a coat/hat hanger when I was younger. Loved that thing. Made one later for my sons.........
For that use, why not! Not sure I would want one on say a westsail 32 or equal bigger boat. But a smaller 20 something boat, what the hay.
Then again, some TP52's re coming out with tillers more than wheels. IIRC one yr had 12 made, 11 were tillers vs one wheel steered! Grant a TP 52 is a 52' sport boat for the races that are being done in the med, not for trans-pac races as originally designed........tillers appear to be metal or composite from pics.............
that is as far as i will comment from a 2 yr old thread being revived! LOL along with my 8' pram I built as a teen had a solid tiller, my stepdads 21' boat he built was also solid intially, until a shop class I had in 9th grade, I made a laminate tiller. My tiller on my 30'r is solid now that I think about it..........a laminate would look better........hmmmmmmm... dang it, another project to worry about.......... shoot the person for bringing the thread back up, or better yet, Hit him with a baseball bat!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #23 of 33 Old 09-02-2010
L124C's Avatar
Originally Posted by SEMIJim View Post
In my exceedingly short experiment with wood working, during which I did a lot of studying, I learned that a properly made up, properly glued joint, using modern glues will exceed the strength of the surrounding wood. (Excluding end-grain surfaces, of course.) I also learned that even the most perfect-looking piece of straight-grained wood can have hidden defects (knots, pitch pockets, grain anomalies) that will only be revealed when you try to work the wood (uncovering them), when it unaccountably moves or warps later on, or when it fails under load. Also there is the question of grain orientation vs. load direction. Lamination, properly done, solves all these problems.Jim
This is the main reason we use Glue Laminated beams in construction. The other being that a camber (arch) can be engineered into them. Spans are achieved with Glu Lams that couldn't even be considered with a regular timber beam. Interestingly, they (wooden beams) are more fire resistant than steel beams. But then...I digress far off topic. If the fire resistance of your tiller becomes an issue, something has gone horribly wrong!
oysterman23 likes this.
L124C is offline
post #24 of 33 Old 09-02-2010
One of None
deniseO30's Avatar
I don't know if it was mentioned.. but KEEP A SPARE TILLER ON BOARD!!!
yes I yelled
My last project!
deniseO30 is offline
post #25 of 33 Old 11-03-2010
Interesting thread..
I just bought a Holder 17 and the tiller just seems.. I don't know, unconvincing. Its a small boat and of course, has a not very long tiller.
I suspect I will spring for a laminated tiller at some point. However, I had a long hard look at some axe handles, so I was interested in the wheelbarrow/baseball bat idea. Has anyone actually tried these "alternate" approaches?
Tazsprout is offline
post #26 of 33 Old 11-04-2010
L124C's Avatar
"A not very long tiller"?...Oh yeah, we used to call that - short! The Wheelbarrow handle would be more than strong enough, but may be tough to find new. For 17 feet, I would think you could find shovel or post hole digger handles that would work for about ten bucks. You'd probably want to cut a few feet off, then simply mill the end to fit in your hardware.
L124C is offline
post #27 of 33 Old 09-21-2014
asdf38's Avatar
Re: Place to buy solid wood tillers
I'm a bit torn here. My current tiller is probably original and solid. But after probably many sandings/refinishes, including by me last year I think it's thinned out a bit. Now it bangs around a bit in the slot on the transom hung rudder. Overall it just doesn't instill a feeling of strength that I'd like for such an important item.
On the one hand, I'd love to make the tiller, but that would realistically mean solid.
On the other hand I see that Ruddercraft.com sells a laminated Contessa 26 tiller for $169. That's honestly not bad. And buying it would cross one item off my to-do list.
Contessa 26 Laminated Mahogany and Ash Tiller, Rudder Craft Inc.
asdf38 is offline
post #28 of 33 Old 09-21-2014
TQA
Bombay Explorer 44
TQA's Avatar
ZOMBIE THREAD ALERT
It is worth while looking at axe handles as they make good tillers.
36 inch hickory axe handle is $10.79 from Sears.
TQA is offline
post #29 of 33 Old 09-21-2014
When I hear about all the trees down in storms and orchard bulldozed by drought down there in 'merica' ,I think of the wonderful supply of hard woods ,free for the picking. A yew branch has within its bark a hidden tiller (from experience) Lots of other parts are also hidden in similar locations (from experience)
Capt Len is offline
post #30 of 33 Old 09-21-2014
Schooner Captain
UnionPacific's Avatar
Originally Posted by miggidy View Post
The tiller on my Columbia 22' busted the other day after 30+ years good service.
I've been looking around to find replacement tillers, but they all seem to be mahogany/ash laminates.
Is there any particular reason for this, and does anyone know where to buy solid wood tillers?
try sailors exchange in st augustine FL. They have a TON.
UnionPacific is offline
First time sail boat buyer martinojon Boat Review and Purchase Forum 20 05-26-2014 09:16 PM
Best place to buy a boat jdinafrica Boat Review and Purchase Forum 13 08-26-2006 09:01 AM
place to buy mast stand for trailer? steve55121 General Discussion (sailing related) 0 04-13-2005 10:10 AM
Fischer Panda Owner''s Forum geoffschultz General Discussion (sailing related) 2 12-29-2003 10:16 PM
