Old 08-16-2008
Survivor is on a distinguished road
washing halyards / line / sheets
I bought an older sailboat that's in pretty good condition. However, the halyards, lines and sheets are grungy but are still usable. I don't have the money to buy new but would like to wash them and perhaps make them softer. I'll probbly take them to a laundrymat with the big round sideways washers but don't know if one type of soap or a softener is better to use. Need advice.
Old 08-16-2008
wbrakman is on a distinguished road
I've just used a big bucket and soaked my old lines for a couple of days in water with Joy brand dish soap followed by another soaking with downey fabric softener. Good results.
I'd be a little worried that a commercial clothes washer could chafe and work the lines, causing them to weaken. Good luck.
Hank
Old 08-16-2008
Allanbc's Avatar
Allanbc is on a distinguished road
Washing lines in a machine is fine. Use a mild soap. It is best to put the lines in a mesh bag when you wash them.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 08-16-2008
use as mild a soap as possible, as strong detergents can harm the lines. Also, don't recommend using a washing machine, since the agitator can damage the lines as well. Best choice would be a big tub or kiddie wading pool.
Old 08-16-2008
tommyt is on a distinguished road
Use the washing machine. If the lines are so bad that the washer is going to cause abrasion problems they probably need to be replaced in any event. However, I usually don't see washers with anything but rounded corners, so abrasion should not be a problem.
Put them in something to prevent the spaghetti effect. Either a mesh bag or a pillow case works just fine. Mild detergent, and downy smells nice and makes them softer . Hang them to dry them!
Old 08-16-2008
Saildoggie's Avatar
Salty Dog
Saildoggie is on a distinguished road
I have coiled them first and then plaed them in our washing machine.
I do place them in a mesh dive bag as well, then re-coil them and air dry, they even smell all fresh, handy for when you happen to have a sheet in you teeth!!
An over 40 victim of fate
Old 08-16-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
have been washing halyards and lines in the washing machine for years with no ill effects to the lines. I put them in mesh bags with an old sock tied around any shackles. hang in the garage to dry. They come out great. you may have to include some old towels in the load to balance it out for the spin cycles.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 08-16-2008
Saildoggie's Avatar
Salty Dog
Good idea on the old socks, got plenty of them with this dalmation puppy around!
I have been getting away with washing lines in the machine, The Admiral did come unglued when she caught me washing my koi pond filters in there tho!
Old 08-16-2008
Might be wise to do the washing on gentle cycle just in case though.
Old 08-16-2008
billyruffn's Avatar
billyruffn will become famous soon enough
True confessions
Years ago, before I knew better I decided to wash the running rigging in the washing machine. Not having the sage advice given above I just dumped them in, put in the soap and let her rip. No mesh bags, no tightly coiled line to interfere with the washing action.
Result: a very clean, multi-colored rat's nest that took hours to untangle.
Knot usage for sheets and halyards Zanshin Gear & Maintenance 55 05-15-2007 08:35 AM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
