08-18-2008
Originally Posted by bruceyp
Yesterday I motored out to some bigger water and had a great sail on a beautiful day. Wind 12-15. Seas 1-2 feet. Really great. Sailed back to the beginning of the channel to head in and the engine overheated again. I have a Yanmar 2QM15 installed by a PO years ago in my C&C 29.
The last time this happened while investigating what could be wrong I opened the raw water strainer, saw that nothing was blocking the water flow and closed it back up, restarted the engine and the water flowed normally. So I figured if it worked last time , it could work again. Yup, it worked.
What is going on here? Is there an air lock that needs to be broken ? Is this going to be part of my SOP? I'm sure that running the impeller dry isn't a good thing.
Has anyone run into this before and/ or have suggestions as to what to look for?
Thanks,
BP
Probably draining back from heeling and your impeller is worn and can't re-create the flow very well.
Try closing the seacock when you go under sail, but stick the key on the valve so you HAVE TO open it to start the engine. If it starts with no problems it's due to drain back. If it's a major PITA when you haul move the seacock to the centerline...
It could also be that your strainer is well above the static water line and gravity automatically takes over even without heeling. If that is the case move it lower in the boat..
______
-Maine Sail / CS-36T
