08-18-2008
I hope they carry a spare alternator. It isn't good to have a single point of failure. I'd also point out if they lose their engine, they're borked. IMHO, it is better to have some redundancy when it comes to charging the batteries. Having a genset, engine alternator, solar panels and wind generator would give you far more flexibility in an emergency.
Originally Posted by SteveInMD
Yes, it may not be the right choice for northbay, we really need more info. I was just pointing out that a (properly installed) alternator can be a very powerful charging source. In some situations it's the best way to go. I use a generator myself.
I've seen a setup with a 270 amp alternator that has been in service for years and has many ocean crossings with no engine bearing problems. The boat runs a freezer, fridge, and two small air conditioning units off an inverter. The only charging source at sea is the alternator.
