Old 08-18-2008
Petar is on a distinguished road
Propeller damage
Hi,
I have a fiberglass sailboat with stainless steel inboard engine shaft and a bronze "Max prop" propeller on it. When I purchased it 4 years ago during inspection I've noted that zinc anodes attached to the shaft and propeller (same as on the photo) were in reasonable condition. I kept the boat in the water for another 3 years and last year in July I hauled it out for painting when I have noted that both zincs were just about gone which I have replaced with new ones.
This year in May (10 months after the last haul out I noticed that the propeller zinc was missing but did not haul it out until last weekend when I noticed that both zincs were gone completely and unfortunately one of the propeller blades was found with pittings as per attached photographs. Other two blades are still in perfect condition.
Over last four years since I am keeping the boat in this marina I've heard people talking about stray currents damaging boats / propellers and shafts and some of the people use additional zinc anodes attached to boat's battery negative terminal and submerged in the water to protect from this.
Is this a solution and if not what would you suggest?
Petar
Old 08-18-2008
Sea Slacker
brak is on a distinguished road
You really need to change the zincs a bit more often I'd say every 6 months is not too soon.
Old 08-18-2008
You should generally replace zincs when they're down to 50% of their original diameter.
Old 08-18-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
+1 to both of these suggestions. Your zincs should last 6 to 9 months. Significantly more or less is indicative of a problem.
"Clean bottoms are FastBottoms"
Folding Propeller Problems slj145c Gear & Maintenance 4 05-21-2008 08:39 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Structural Damage Dan Dickison Buying a Boat Articles 0 06-16-2002 08:00 PM
Propeller Problems Mark Matthews Gear and Maintenance Articles 0 05-27-2002 08:00 PM
Check the Propeller Tom Wood Gear and Maintenance Articles 0 02-25-1999 07:00 PM
