Old 08-19-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Lewmare Super Lock or Spinlock XAS Rope Clutch?
I want to get a double rope clutch set up for my Main and Jib halyard. I've narrowed it down to 3 possibilities.
I've heard Lewmar doesn't wear out lines as fast.
Spinlock grips harder
and Garhauer doesn't make any for 1/4" line, but I've emailed to see if they'd start carrying them.
The spinlocks (IMHO) look better than lewmar, but I've personally seen 2 of them break on 2 separate boats. They continue to hold but the handles break off either when they're left open and someone steps on them, or if there's a bad lead coming out of the clutch they won't close all the way, if you force them, you can break the handle off by hand.
I believe the handles breaking on the spinlocks are due to sun exposure and the plastic getting brittle. Does lewmare have the same issues? If Garhauer would make clutches for 1/4" lines, this wouldn't be an issue, as they use aluminum handles.
Merit 25 # 764 "Audrey"
Old 08-19-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I'm quite happy with my Lewmar clutches.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 08-19-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
I am happy with my spinlocks!
Old 08-19-2008
According to the PS magazine tests, the Lewmars grip almost as well as the Spinlocks but chafe/abrade the line much less...which means your lines will last longer.
Also, a problem with the spinlocks is that under high loads they are not releasable without easing the load first. That is not the case with the Lewmars.
However, the Spinlock and Garhauer clutches can handle a wider range of line diameters than can the Lewmars, so you need to get the right Lewmar for the line size you'll be using, and you may run into problems if you decide to change to a thinner or thicker line at a later date.
Old 08-19-2008
zz4gta's Avatar
I think the lewmars would be a better choice for me then. I plan to use 1/4" halyards, and if anything, I'd go bigger the next time around. I just want to make sure they're beefy.
Old 08-19-2008
BTW, the Lewmars are less expensive than the Spinlocks last I checked.
Old 08-19-2008
dvpamenter is on a distinguished road
I have had the Lewmars for 8+ years and they work as good today as the first day.
Well priced too.
Don
Clear Sailing
Alado agent - Canada
Navigating locks GoodOldBoat Learning to Sail Articles 9 4 Hours Ago 01:46 PM
Rope mats GoodOldBoat Gear and Maintenance Articles 13 12-11-2011 08:42 PM
S2 27: Mainsheet is lead through Spinlock clutch...Opinions? scuppers S2 4 05-20-2008 11:35 AM
Installing Spinlock XTS clutch on mast garymcg Gear & Maintenance 7 10-24-2007 03:20 PM
