Old 08-19-2008
groundhog is on a distinguished road
fuel filter system..
I was in this guys boat and he had made this switchable fuel filter system.
It was basically a piece of plywood where he mounted 4 filters and some switches.
There was two paths and in each path was a coarse and fine filter. When one path clogged up, you just switched over to the other side.
I want to make one.
Does anyone have info, suggested part numbers etc?
I also saw the filter boss data sheet. Seems pricey. Maybe it's actually a good deal?
groundhog
Old 08-19-2008
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
Filter Boss looks interesting:
http://www.ktisystems.com/Articles.asp?ID=122
If I was going to make it myself, and that's probably what I would do, I'd look to McMaster-Carr for manifolds, piping, valves, etc. and Racor for the filters.
McMaster-Carr
Old 08-20-2008
Moonfish's Avatar
Cruiser/Lats and Atts TV
Moonfish is on a distinguished road
Though it is a bit pricey, the Filter Boss is well engineered and has the very nice feature of a vacuum pressure guage with alarm in the cockpit that tells you when the filter is starting to clog and fail - thus allowing you to switch to the other filter before the engine dies. Probably has other bells and whistles, too...
"Always approach the dock at the speed you wish to hit it."
s/v VENUS
1978 North Sea 33 Pilothouse Cutter (Ta Chiao)
Old 08-20-2008
These seem to me to be kind of pricey and rather unnecessary on a sailboat where the engine hours presumably don't get racked up real fast.
If keeping filters clean and servicable is such a problem that you need a "hot standby" then you need to look at your tank, and/or your fuel supplier. Also, if you make a habit of screening your fuel as you load it you can help prevent problems too.
By all means set up a good filter system, it's truly necessary, but good practices should negate the need for a redundant (read costly) set up like that.
1984 Fast/Nicholson 345
Old 08-20-2008
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Racor makes a manifold with two filters, vacuum guage, and water sensor alarm. Pricey+++++.
Old 08-20-2008
camaraderie's Avatar
moderate?
Faster...it all depends. For example, outside the US/Can fuel quality can be quite scary. I used a baha filter in the caribe and it was just scary what crap and how much water was in some of the fuel.
I have been in close quarters motoring situations and lost my engine and believe me, I had no opportunity to sail.
My dual racor system was put together quite easily by my diesel guy for a lot less than the "filter boss" and provdes an extra measure of safety/security. I have spent enough time upside down in 8 ft. seas trying to change filters and bleed the engine. Now, at first sign of a slowdown in RPM's we just throw a couple of handles and change filters at our leisure.
I believe all Caliber yachts come with this system.
Old 08-20-2008
Originally Posted by camaraderie View Post
Faster...it all depends.....
Point taken, Cam.. I can see that scenario alright. I guess I was thinking more of the typical sailing that most of us do day-to-day.
Old 08-20-2008
christyleigh's Avatar
christyleigh is on a distinguished road
I spent the big bucks for the "filter boss" after having daily engine deaths on my delivery from MD to R.I. Yes.... the PO let the fuel deteriorate in the 2 - 60 gallon tanks, and I should have had the fuel polished before I left (did later in R.I. for $1,000 ) and the tanks cleaned for X $$$ ?, and yada ...yada... yada...... The bottom line for me was Never Again Who or What Ever the fault was.
Now I have totally switchable tank to tank polishing and the switchable filters with warning gauges and alarms. When I thought I had a problem after building the system Andy the owner of FilterBoss (who does live closer to my boat than I do ) came down and helped me diagnose my non-problem.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 31 03-22-2012 02:36 PM
Universal M21, long story and fuel line question BarryL Gear & Maintenance 16 05-12-2008 03:37 PM
Question about the diesel filter system on the boat Tartan34C Gear & Maintenance 3 09-23-2007 05:47 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
