Old 08-21-2008
Seafire327's Avatar
Seafire327 is on a distinguished road
Question Rustoleum Bottom Paint?
Hello All,
I did a search but didn't find any info...
I was poking around Lowes the other day and happened to notice a display with quarts of Rustoleum brand anti-fouling bottom paint. Never knew they made it.
Does anyone have any experience with it?
Thanks
'70 Columbia C26 Mk II - "Klydo"
Boston, Ma
Old 08-21-2008
ehmanta's Avatar
Sailing Junkie
ehmanta is on a distinguished road
I have used their top-side polyurethane paint on my small boats and feel that they are equal to Interlux one-part topside paints. Time will tell how they fair with fading, but the initial feeling is that they are very similar. I can't say about the bottom paint issue, but I would guess that a well known company like Rustoleum would produce somtething decent. The cost is certainly much less
Old 08-21-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
What kind of paint was it? Ablative, hard?
Merit 25 # 764 "Audrey"
Old 08-21-2008
Seafire327's Avatar
Not sure. Took a look at the website which said it was copper based for low to moderate fouling conditions. If I had to guess, I'd say hard.
The price seems fairly economical, but its only sold by the quart. Kind of strange...
Boston, Ma
Old 08-21-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
I use it all the time on my small boats. Works pretty well here in the waters of Charleston. When i used to leave my skiff in the water all the time i would have to pull it once a month or so to give the bottom a quick powerwash. Its a hard paint.
As for their topside paint, its not too bad, again i use it on my small boats. My skiff is going on over a year of being painted with it and its fine.
1972 Pearson 36 S.V. Distant Star
Old 08-21-2008
L02314564's Avatar
Itz That Eazy!!!
L02314564 is on a distinguished road
Their website says it is a Hard paint for use in fresh and saltwater. Thanks for the tip.
THis is from the Rustoleum site:
Boat Bottom Antifouling Paint
Protective coating for use below the waterline.
Hard antifouling coating that slowly releases copper, preventing the build-up of barnacles, algae and other marine growth. Hard antifoulings are best for powerboats, racing sailboats, or boats that are regularly hauled and cleaned. The biocide will oxidize when hauled and stored for the season, but can be sanded to regain antifouling protection.
For mild to moderate fouling conditions in both fresh and saltwater
Formulated for use on both trailered boats and boats that remain in the water all season or all year long
45% cuprous oxide (copper)
Not for use on aluminum surfaces as the copper in the coating will react with the aluminum
Newly painted boats should be launched within 60 days of painting for best antifouling performance. If not launched within 60 days, the surface must be scuff-sanded.
Priming
Bare Fiberglass - priming is not necessary
Bare Wood - apply a base coat of Rust-Oleum Boat Bottom Antifouling thinned with 10% mineral spirits, and use full-strength antifouling paint for subsequent coats.
Previously painted surfaces – can be applied directly over most aged hard antifouling coatings.
Bare Metal (excluding aluminum) - apply a base coat of an epoxy primer
Boat Type Paint Needed*
14' Rowboat 1 qt.
14' Outboard 1 qt.
18' Runabout 3 qts.
20' Sailboat 3 qts.
24' Runabout 3 qts.
24' Utility 3 qts.
25' Cruiser 3 qts.
* Based upon 2 coats applied over existing finish. Bare wood will require approximately twice as much paint. Unpainted fiberglass and metal will require about 1 1/2 times as much. Coverage will vary with condition of surface and method of application.
Edward
U.S.A.F. Retired
S/V Itz That Eazy!!!
1976 Catalina 27 #2684
Old 08-21-2008
Seafire327's Avatar
Thanks for the input thus far guys, I'll be looking into it some more as I'm working from topsides to keel, and have only just begun
Boston, Ma
Old 08-21-2008
RickQuann's Avatar
RickQuann is on a distinguished road
Thanks for the heads up SF, nice to know info
Old 09-24-2010
Yodagwb is on a distinguished road
Rustoelum
For some reason I am not so sure that the manufacture of Bluewater Marine paints, including bottom paint, doesn't also manufacture Rustoleum.
Confessions of a bottom feeder PracticalSailor Gear and Maintenance Articles 9 06-18-2008 04:33 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
