Old 08-21-2008
SkipperBob is on a distinguished road
Triple Anchor Swivel
A couple of years ago I saw a Triple Anchor Swivel advertized, but have lost track of where and cannot find it by web search. This is not the in-line single anchor, triple swivel. It is designed to accomodate three deployed anchors with a heavy duty swivel to help prevent anchor rode twisting. If anyone remembers this item, would appreciate tip on where to find it as well as If anyone has first hand experience with it, I would greatly appreciate any advice.
I am aware that serious cruisers generally recommend to avoid using swivels, but this product is pretty heavy duty.
Old 08-21-2008
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
They are discouraged to use a swivel with laid line. Because as the line tensions and detensions while the boat horse around on the anchor, it is the detensioning of the line where that swivel will allow the laid line to cockle, thus weakening line as the cockles are pulled into the lay when that line goes under tension again. With a double braid or plaided line or chain the swivel is a good thing to have.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 08-21-2008
mazzy's Avatar
mazzy is on a distinguished road
Was it this:
Bridle Plate
Mike
Old 08-21-2008
Thanks, That's it. It's for hooking up to a mooring using a bridle of two lines on a monohul or three lines on a multihull.
I've been thinking of using it to deploy three anchors in storm conditions to the bridle with a heavy line run from the bridle swivel to a heavy duty attachment point at water level below the bow sprit kicker. I would also attach a bridle as a back up in case the atachment point at water level failed. I'm thinking that there would be a number of advatages to this direct attachment. The major advantage is that it avoids chafe at the bow chocks.
Old 08-21-2008
I went on the web page that "mazzy" cited. They now have a double bridle plate that does exactly what I want to do.
Old 08-21-2008
RXBOT is on a distinguished road
D.y.i.
You could buy shackles & swivels & fabricate the plate yourself if the saveings were enough to make it worhwhile.
Old 08-23-2008
ANCORALATINA's Avatar
ANCORALATINA is on a distinguished road
Hi SkipperBob,
One question? Are you planning to make a permanent mooring, with three anchors??
If you want to use three anchors during a storm, I hope for you that you will not have to leave, otherwise, you will not be able to retrieve the three anchors??
What about a single oversized "storm" anchor?
Ancora Latina
Old 08-24-2008
Another entry
Anchor wars sequel # ???
Old 08-24-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
No worries ..not availibal in our language....
Old 08-24-2008
Still
Actually it is. I read the web pages, very similar to Manson, Spade etc.
Triple Spreader Shroud Tension Mike36 Gear & Maintenance 12 08-08-2008 11:08 AM
Rigging The New Triple Blocks? SEMIJim Gear & Maintenance 10 10-18-2007 09:34 AM
SailNet’s Pro-Am Regatta at The Bitter End Dan Dickison Racing Articles 0 11-12-2000 07:00 PM
