08-21-2008
Harbor canvas?
I have a Bristol 32, which not unlike many older boats, has a cockpit configuration which does not allow for a reasonable bimini. My main traveler traverses almost at the middle of the cockpit. As such, I have devised, (concocted), a type of "harbor canvas", as I have heard them referred to in the past, which is essentially a sheet of sunbrella canvas, about 6'x6', with eyelets along the front and a sleeve aft. My intent is to lash the front to the deck at the leading edge of the dodger, and probably even go so far as to Velcro it to the front of the dodger, just above the window. The aft end will have an awning pole through it, which will go aft to a block on the back stay, as well as having lines to the cockpit coaming. This configuration will allow use while sailing. Anyone ever done anything like this? It sounds pretty sturdy, although I do anticipate much in the way of lateral instability, (vibration), which in my opinion will be inevitable, and it is a question of how much wind the rig will actually handle once configured.
Any thoughts, better ideas, or hearing from someone with a similar configuration would be welcome.
Thanks,
Dr. S.
Dr. S.
"Eh Winds Up, Doc?"
Bristol 32
