08-23-2008
Wire condition after 3 years in Hayn fitting...
Thought I would share these pictures for those interested in using mechanical compression fittings. This is especially for all the naysayers that claimed I would be dis-masted if I didn't use gobs of sealant inside the fittings to keep the water "out"
This wire was the lower backstay terminal fitted with a Hayn Hi-mod compression fitting three years ago and has spent time in the tropics, California, and Alaska. There is absolutely no corrosion, just a little bit of dirt and grime, and absolutely no distortion of the wire as evidenced by its ability to return to its normal lay. I cut this length out of my backstay to fit insulators (also Hayn). I think I can be confident I have found the ultimate rigging terminals. Could you disassemble a norseman or staylock and put it back together after 3 years without replacing any parts?
