Removing the deck from the Hull for a refit - Page 2 - SailNet Community
post #11 of 13 Old 09-18-2008
Owner, Green Bay Packers
Wes,
Here are the promised photos.
You can see that you have to lift your tiller for access but that's no big deal. You can also see the pockets, or lockers, within the gunwale in the last photo.
sailaway21 is offline
post #12 of 13 Old 09-18-2008
tommays's Avatar
I have done it on a 16 and 18 ' Donzi powerboat that had steel fuel tanks under the fiberglass liner So there was no other way to go
The good thing was they have boat lift rings in the deck that made it easy to lift
The bad news is the better the boat is made the harder it is to get apart ,Donzi glasses the joint as a final step and it had to be cut while doing a handstand
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 13 Old 09-18-2008
The one I just tried had several places where the top was glassed to the bottom of the hull. All the way around the top and then at two bulkheads and several other places. There was no simple way to pull the top without cutting something up. It is about half way into the trash bags in little pieces. My grandson showed up to visit gramps, so I did not get it all the way cut up.
Pick your fights. The boat needed an impact crack repaired about 10 inches long. The glass was cracked around where the mast steps. The foam under the bow storage area and under the floor was pellets like those in a bean bag chair. Maybe when the boat was new the glass was strong enough to be supported by loose pellets, but no longer. So far I have not found a single wood stringer. The stringers and supports were formed around foam. To fix this boat would have required lots and lots of work while I don't even have the original mast, rigging, or sails. It can be purchased in sailing condition for about 1500$
I am going to restore a boat, but I want a usable boat to start with!
runner is offline
Hull Hard Spot leading to Interior Refit Blueskyzephyr Sailboat Design and Construction 9 01-16-2008 04:44 PM
Soft Deck Repair davidpm Gear & Maintenance 38 12-05-2007 12:54 PM
Installing Treadmaster Nonskid Sue & Larry Cruising Articles 0 07-11-2004 08:00 PM
Deck to Hull fastening.... john232 Boat Review and Purchase Forum 6 01-23-2004 08:11 AM
