Old 08-24-2008
deniseO30's Avatar
Lies about her age
Stink
I'm still trying to find the cause of a stinky port settee bunk. I think..really, the only logical answer I have is that it's coming from between the hull liner and hull that is behind the back rests. Nothing has killed the smell, I guess because because it's inaccessable. This week I'm going to look and see if it's possible to get inside there with long brushes like those used to clean boilers. Sure could use some ideas on this. Don't really want to cut access holes behind the backrests although I could.
Thanks!
Old 08-24-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Just a thought, don't know if it would work for ya but, Clorox has a product called Green Works, I use it in the shower sump and gray water tank.
Get a small Hudson sprayer and spray between the liner and hull, soak it good and let run, do it as much as you like, then rinse with water, it will all run to the bilge and will pump OB. Green Works is environmentaly safe so no harn, no foul
Kills the bad smell, leaves a good one
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 08-24-2008
camaraderie's Avatar
moderate?
Are you sure the prior owner actually got off the boat?
Old 08-24-2008
deniseO30's Avatar
Lies about her age
OMG hope he didn't leave a cat,gerbil,hamster,mouse,ferret, or other
behind!
Old 08-25-2008
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
I would forget about the bleach and all the other harsh chemicals and give your bilge a bath in 'KO' which is a bacterial head tank treatment. Brush it? Yes. But to stronger chemicals like bleach are just going to kill everything inside and outside your boat (Raritan?).
Save the bleach and water solution for cleaning up mildew. 'KO' kills odors and I have no affiliation with this company.
My experience is that it works well as long as there is enough ventilation for it to do it's job. Not entirely 'green' but better than putting engine oil in the surrounding water.
I find it works great as a holding tank treatment too.
Old 08-25-2008
Omatako's Avatar
Omatako will become famous soon enough
behind!
Enduring smells like that are often caused by something dead. Mouse, rat, whatever and it doesn't mean the PO left it, it could have snuck in. It's hard to imagine what else would for no apparent reason start to smell.
On a previous boat we had a small bird crawl into the air intake port into the engine room and got stuck and died. It was easy to find and didn't smell for long but a dead rat or similar will resist just about any chemical treatment and might even be made worse by chemical exposure. They smell bad anyway and are quite durable. If it is something like that and you can't reach it, the smell will eventually go away but it's the thought of the remains in the boat that are a little unpalatable.
Are there no other signs of "visitors"?
Good luck
Andre
Old 08-25-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Hmmmm...could be we have another makings for a snake on the boat thread...
Diesel stink bmcald Gear & Maintenance 17 10-27-2009 05:20 PM
Blowing like stink in NJ! teshannon Off Topic 13 05-13-2008 12:02 AM
A gripe - The most unseamanlike vessels on the planet? Lancer28 Seamanship 67 10-11-2007 11:11 PM
Does your boat stink? Toyboat Gear & Maintenance 35 08-03-2007 04:26 PM
Things I Learned the Hard Way! Pirate's Booty General Discussion (sailing related) 116 07-25-2006 12:13 PM
