08-26-2008
What brand is the pure sine wave inverter???
BTW, generators and inverters are generally rated for resistive loads IIRC, and an inductive load can require an inverter/generator of a much larger rating...
What does your friend's laptop draw for power... it may be that your laptop has a larger screen, etc, and requires just enough power that the 300 W inverter chokes on it.
