Old 08-26-2008
BluewaterBruce is on a distinguished road
Need Advice on 6V/12V battery amp hours
Greetings!
As we progress into new areas of the "project" there is more to learn. The vessel is a 48' ketch and it came with 8xT105 6V Trojan batteries/12V system for the house bank. I understand flooded/gel/AGM and the differences but what I'm looking for is the conversion from 6V amp hours to 12V amp hours???
If a 6V battery is rated at 220 amp hours and you place two of these in series creating a 12V system - would the total amp hours be 440 or? Seems 6V batteries have a much higher amp hour rating.. I suspect the total amp hours are going to be 220?
Thank you in advance for your replies!
Old 08-26-2008
btrayfors will become famous soon enough btrayfors will become famous soon enough
Bruce:
Two Trojan T-105 6-volt golf-cart batteries in series equal a total of 220AH @ 12 volts.
If you connected them in parallel, you'd have 440AH @ 6 volts!
FYI, 8 T-105s in series/parallel for a 48' ketch (for a total of 880AH @ 12 volts) sounds about right in terms of house batteries.
Bill
Old 08-26-2008
Thanks - Learning as I go but it's a goin good!
advice on small 12V system?? Northeaster Gear & Maintenance 51 03-23-2007 01:53 PM
