Old 08-26-2008
souljour2000's Avatar
souljour2000 is on a distinguished road
Question about drilling new cockpit drains
I am widening my Hunter 20 cockpit drains from 1/2 inch to 1 inch or 1 1/4 . I am wondering if there is a way to keep the "bottom" of my current hole when I am drilling out the new hole if you follow.I dont want to widen the hole down at all but only up and out to the sides so I don't have water coming in more than It should on windy days. I am trying to think how to pilot the hole without slipping and while keeping the new hole where I want it.. Does anyone know of a jig system or some other way to achieve this? Thanks....
Old 08-26-2008
newpbs is on a distinguished road
I'm not sure that I follow you but I will give it a try. It sounds like you are working above the waterline and that you want to use a hole saw to make a larger hole in your hull. In that case I can see the need to have some material to hold the pilot drill while you operate the hole saw. If this is the case I would fashion a shallow wooden plug to fit the existing hole. Give the plug a little taper so that it fits snug in the hole and drill out the new opening accordingly.
Another approach would be to use a course rasp to widen the hole to the required size.
BTW, if you are working below the waterline...good luck.
Paul
Old 08-26-2008
The plug suggestion sounds like it could work well..thanks for the help!
Old 08-26-2008
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
Mark the cockpit floor, and use a dremmel, or a larger sanding roll for a drill. It will work quick, and clean. Dusty as hell, but the hole will be clean....GOT A STEADY HAND?
Old 08-26-2008
The other way to do it is to tape or screw a board over the area you're planning on drilling the larger hole... and that will allow the hole saw arbor to have something to bite and keep the hole saw centered. I've used this technique for doors, through-hulls, and solar ventilators.
Old 08-26-2008
Maddog046 is on a distinguished road
This is easy, place a .5" and 1.5" hole saw on the same drill chuck. The .5" saw will center the 1.5" hole saw and you are good.
Old 08-26-2008
Actually, this is a horrible idea, since the OP wants to enlarge the existing hole asymetrically.... so that he doesn't cut andy further down into the cockpit floor. It would help if you actually read what the OP wrote...
Originally Posted by souljour2000 View Post
I am widening my Hunter 20 cockpit drains from 1/2 inch to 1 inch or 1 1/4 . I am wondering if there is a way to keep the "bottom" of my current hole when I am drilling out the new hole if you follow.I don't want to widen the hole down at all but only up and out to the sides so I don't have water coming in more than It should on windy days.
Old 08-26-2008
RXBOT is on a distinguished road
Holesaw?
Is there such a thing as a !/2 holesaw .the smallest holesaw I'm aware of is 3/4 inch. But the idea is good and you could drill a 3/4 inch hole using a solid drill with turned down shank and use 3/4 inch holesaw and a larger holesaw as suggested.
Old 08-26-2008
thanks for all the input everyone! Holesaw seems like a good way to go.I am itching to do this but havent put the boat in the water yet..When I do maybe I can simulate a large amount of water in the cockpit and see what gives...it is just that 1/2 " is so obviously small I am tempted to do the hole before I even test the cockpit...hmm..I am just not sure where the waterline is gonna be with this thing so better play it safe...and wait till later to drill these holes I know I am gonna drill anyways...lol
Old 08-26-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
You can also enlarge a hole in fiberglas with an electrician's reamer which is designed to be used on junction boxes and the like. It'll chuck in your drill and will allow you to progressively widen the hole to size. Home Depot carries them in the electrical department. If you want to open the hole off to the side you'll probably find that a Dremel tool or a Rotozip will do the job quite well using a dry wall cutting bit. I prefer the Dremel myself for it's versatility and the Rotozip drywall bits will fit it. Again, available at Home Marina.
Lighten up Dog, I had a bit of trouble cottoning on to the OP as well. and you just layed into a member with only five posts who might have been under the impression we're friendly here. (g)
Wm. F. Buckley, Jr.
Cockpit drains gg30citation Gear & Maintenance 40 02-27-2008 11:51 PM
Cockpit Drains KeelHaulin Gear & Maintenance 4 01-15-2008 01:35 PM
Center cockpit or aft cockpit? capsbond Boat Review and Purchase Forum 11 08-09-2006 12:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
Day Sailers w/large cockpit and head? Ethan_nyc Boat Review and Purchase Forum 6 07-14-2001 08:09 AM
