- Quick Menu
08-26-2008
2:1 Vhf Swr
I just installed a new Raymarine DSC VHF.
I have a mast top antenna with a balun. It looks like it's a 1/2 wavelength, 36 inch antenna.
When I was a HAM radio operator, I always tried for a 1:1 SWR. I measured mine at 2:1 using a SWR Bridge.
Anybody else ever measure their SWR?
I think 2:1 is not bad, but I was just wondering what others are seeing.
Chris
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Reason: DCS to DSC
08-26-2008
Anything less than 2:1 is pretty good for a VHF unit. Ideally, you'd have it be 1:1, but I don't think that is all that feasible. Using a Shakespeare SWR meter, I found that the setup on my boat is about 1.5:1 or so, varying a bit with the frequency.
08-27-2008
Are u sure u have a balun ? and not just a matching coil, a balun does nothing more than change an unbalanced line (ground referenced) to a balanced line no ground reference. You normally use a balun when you have radio op that has the outer cable shield tied on to ground (basically the 3rd prong on your AC power plug) and u want to feed a split dipole antenna. normally used for SSB radios, not VHF . I've never heard of VHF radis having a Balun attached. Just wondering..
A King needs a Crown
08-27-2008
Handsome devil
Sounds like we have a new Radio Guru...  ...Good I know nothing
08-27-2008
Check for water in the coax shield, or if the coax cable got crimped or pinched somewhere along the run. My SWR was so bad due simply to old deteriorated coax that my Uniden VHF was self limiting itself.. What type of meter are you using? Remember they need to be calibrated to whatever frequency you are transmitting on.
08-27-2008
Last Grumpy Old Sailor
That would be a matching coil. Baluns are used to transform unbalanced transmission lines to balanced antennas. (E.g.: Coax to dipole.) Hence the name: Balanced to unbalanced transformer.
That would be about right at 162MHz.
2:1 is usable, but I wouldn't like it. I would want to get that down to under 1.5:1.
I've been meaning to. I keep forgetting  . Many, many things to do. The list seems to grow longer, as time goes on, rather than shorter. The radio works, so there are much higher priorities. Nothing I can do about it atm, anyway, being as the antenna is a one-piece fiberglass thing.
I think 2:1 is not bad, ...
I don't regard 2:1 as acceptable, but that's my opinion.
Jim
s/v Abracadabra
1976 Pearson P30
08-27-2008
Wow. You guys are picky sometimes.
Since I have a 1/2 wave antenna, I agree the base is not a balun, but just a means of mounting it.
The connections at the mast top are old, 20 to 30 years, so I plan to run new coax at some point.
I held an advanced class ham license (WA6TZE and KB7KJ) and also a First class Radio license, plus a BS in Electronic Engineering, so I have a pretty good idea of what is going on.
Mainly I just want to bring up SWR (Standing Wave Ratio) as a topic, since it is important in radio commnuications.
- E.B. White
08-27-2008
Just want to say.........What the Hell are you guys talking about??????
Ya turn the damn radio on, you switch it to what ever channel you want to talk on, you push the friking button on the microphone thingy and you talk into it. It's simple.
Than you listen to what the udder guy be saying.
Courtney is My Hero
08-27-2008
Doesn't always work that way TJK... BTW, you forgot to say "stop pushing the microphone thingy button when you're done yakking" so you can hear them. but it does explain why you never seem to hear us when we reply to you hailing us.
08-27-2008
ok, I'll remember next time to STOP pushing the button thingy.
My radio works and I still have no idea. Never claimed I did.........
Courtney is My Hero
| Thread Tools |
Search this Thread |
