08-26-2008
I think you'd be better off leaving the fuel pump downstream of the Racor filters, and leaving the vacuum gauge as a warning tool for filter quality. If the fuel pump is after the Racors but before the rest of the fuel system, it should allow you to bleed the fuel system pretty thoroughly... a small rubber fuel bulb upstream of the Racor filters will allow you to bleed any air from the Racors themselves pretty reliably.
