Old 08-27-2008
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
rebuilding propane locker
My LPG cylinder is steel and I would like to replace it with either aluminum or the plastic variety that has just appeared. However, the propane locker is only 14.5 in deep, too short for any of the cylinders I have found.
If anyone knows of a source of smaller cylinders please let me know.
But I suspect I will have to replace the propane locker, which is built into the port seat of the cockpit and protrudes into the lazarette. I haven't seen any replacements for sale, so I assume I would have to construct one from StarBoard or plywood and fiberglass.
Has anyone done this? Are there photos anywhere?
Thanks
Micheal
Fluctuat nec mergitur
  #2
Old 08-27-2008
The 16# composite propane tanks are very reasonably priced, and I picked up two for my boat for less than $50 each. They're about 1' in diameter and 18" high. I'll be building a new propane locker for them this fall.
  #3
Old 08-27-2008
Arf!
If you would be so kind, could you document the project with photos
I can wait until spring to do mine...
  #4
Old 08-27-2008
Will do, if I can remember to.. Planning on making the new locker out of 3mm plywood and fiberglass.
  #5
Old 08-28-2008
RXBOT is on a distinguished road
10 pound
Cylinders r available,15 1/4 inches high, 12 inch diameter. One thing to watch for with the composites is the neck fitting and valve being made of different materials.
  #6
Old 08-30-2008
sander06 is on a distinguished road
I've seen large diameter PVC pipe used for some tank storage installations.
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
  #7
Old 08-30-2008
That's usually for the 1 lb. disposable tanks, not large refillable ones.
  #8
Old 01-18-2009
jandkellis is on a distinguished road
Smile Propane Lockers
Michael,
I know that this is very late but I just saw your message concerning P-323 propane lockers and I am desperate to find lockers to install on my 323. Did you eliminate yours in favor of larger tanks and if so, are they still available by some chance. I am prepared to pay handsomely.
Thanks,
Jim
You may post attachments
You may edit your posts
Something New to Worry About - Propane Hazard jparks Gear & Maintenance 8 06-18-2008 05:52 AM
Propane locker on a Tartan 30 owlmtn Gear & Maintenance 0 06-06-2006 06:22 AM
Propane Locker windship Gear & Maintenance 5 04-13-2004 04:55 PM
Propane Locker windship Gear & Maintenance 0 04-09-2004 03:24 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
SEO by vBSEO 3.6.1
