Old 08-30-2008
Quickstep192 is on a distinguished road
I need a knob for a GPS mounting arm
My friend's boat has a GPS on an arm that swings allowing the GPS to be positioned either inside the boat, or positioned in the companionway for viewing from the cockpit. It has two knobs that tighten down on bolts to hold it in position. Unfortunately, if you swing it without loosening the knob, the knob shatters. I did that, so I'm looking for a replacement knob. I thought if I could find a mount like his, I could get a replacement knob. I can't seem to find the mount, let alone the knob. I've searched Ram Mounts website to no avail. Any ideas?
Old 08-30-2008
camaraderie's Avatar
moderate?
Is it like this with another extension arm?
If so...West Marine carries them.
West Marine: Swing Mount TO 60LB Product Display
Old 08-30-2008
No, but you lead me in the right direction. I wouldn't have thought of West Marine as a likely source. I wonder if they'll have parts.....
The one I need a knob for looks like this:
Old 08-30-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Hardware store often have a selection of various knobs, plugs, inserts, washers, rings, corks, pins etc. etc. etc. in the fasteners section. I have found all kinds of stuff in that section at Ace Hardware that replaces the odd missing part that would otherwise require tossing the entire device.
"Clean bottoms are FastBottoms"
Old 08-30-2008
moderate?
I believe that is the same company with the extension arm. It is what I use on my boat. They will NOT have the part but perhaps you can write the company that makes it....or trade in your friends broken assembly for a new one. They have good return policies for defective products.
Old 08-31-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Sounds like a defective product, to me. ISTM one tightens the knobs to keep if from moving. So it either shouldn't have moved or should have moved reluctantly. It shouldn't have broken, IMO. Well, unless you really leaned into it--but it doesn't sound like that's what happened.
Jim
s/v Abracadabra
1976 Pearson P30
Old 08-31-2008
SkywalkerII is on a distinguished road
The mount looks like the West Marine version - I have the same one. I have not had any difficulty with the arm or locking knob. Perhaps it is defective. I'd try West.
Skywalker
Old 09-10-2008
resdog's Avatar
resdog is on a distinguished road
McMaster-Carr - more knobs than you can ever imagine
McMaster-Carr
Type in threaded knobs and it'll bring a big selection up
Old 09-11-2008
BreakingWind2's Avatar
BreakingWind2 is on a distinguished road
Try Ram Mounts, they might be able to help.
RAM Mounting Systems, Inc.
Dave
Old 09-11-2008
sander06 is on a distinguished road
Guys, FSTBTTMS was right the first time... ACE HARDWARE or the like will probably have what you need. Look for the simplest solution to any problem, not the hardest (unless that's your "thing" of course!).
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
Handheld GPS Overview Tom Wood Seamanship Articles 0 05-31-2001 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
Advanced GPS Interfacing Jim Sexton Seamanship Articles 0 10-07-1999 08:00 PM
