Old 08-31-2008
watom is on a distinguished road
Packing gland grease
My packing gland has a grease fitting not a zert but a cup that presses the grease into the fitting. My question is what grease should I be using for this application. As a side note the new packing I used seemed too small. I couldn't get 1/4" into the gland, and 3/16 seemed to small, my boat is a Chinese made and I fear the packing gland is metric. The nuts on the studs were metric. So is there metric sized packing?
Old 08-31-2008
stuck 'behind bars'
Robby Barlow is on a distinguished road
Send a message via MSN to Robby Barlow Send a message via Skype™ to Robby Barlow
First of all welcome to sailnet watom!
Secondly it would be helpful to know what boat you're talking about, and until then I can thirdly say yes there is a metric sized packing for your boat, seeing you've got it, as to where to get spares - some additional info would be useful.
If you want to keep your shadow behind - walk facing the sun !
________________________
www.starykon.blogspot.com
Old 08-31-2008
My boat is a 48 Celestial, so where to get packing is the question.
Thanks,
Tom
Old 08-31-2008
btrayfors will become famous soon enough btrayfors will become famous soon enough
Tom,
I have a "Chinese boat", built by Cheoy Lee. No problem finding packing material. The standard U.S. size works just fine.
Re: grease, just use any good waterproof grease, e.g., outboard lower unit grease.
Biggest problem is remembering to give the grease cup a few turns regularly :-)
Bill
Old 08-31-2008
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
I recently had my boat in the yard and I actually bought every size packing in the store and none of them fit! It turned out that since I was in the yard and the boat was loaded differently the shaft was a hair off-center. This meant that 5/16 fit in the top and 1/4 fit underneath.
My engine is mounted offcenter with a flex-coupler so it's always a little off center (apparently not a problem) and when I added a couple new strands in the water I had the same problem. Took the nut off and was a hair off center.
The solution was to take a car jack and put it under the shaft and with a finger's pressure (and no handle in the jack) I was able to put enough upward pressure (very little) to center the shaft and get 1/4 in snug all around.
You could also try taking calipers to the stuff you pulled out of the gland, or taking it to the store for comparison.
Good luck!
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
Old 08-31-2008
gc1111 is on a distinguished road
I would recommend Lubriplate Water Pump Grease (I think it is #115) and give the cup a turn regularly and refill as needed.
Dripless Packing mgotro@sbcglobal.net Irwin 3 05-25-2006 07:41 PM
Shaft Packing f_cousin Gear & Maintenance 1 07-27-2003 07:10 AM
Packing Gland Problems Sue & Larry Gear and Maintenance Articles 0 09-08-2002 08:00 PM
Packing Gland Leaks Mark Matthews Gear and Maintenance Articles 0 06-26-2002 08:00 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
