Old 09-01-2008
terryjoe's Avatar
terryjoe is on a distinguished road
Question Prop Change
I recently had someone dive on my boat to clean the hull. He told me that one of the blades on my prop looked as if it were bent slightly. I have been having problems lately with vibrations.
I have two questions:
Can the prop be changed while the boat is in the water?
What would be a good prop to get for a replacement that isnt too expensive?
Thanks!
Terry
Terryjoe
Pacific NW
1975 Irwin 33
Old 09-01-2008
Warren M.'s Avatar
Sailor
Warren M. is on a distinguished road
You have a number of options, but all would require your boat to be hauled. You could then pull your prop and have it reconditioned by a qualified prop shop if it is not in really bad condition. They can tell you that. I would explore that first as new props are expensive. But removing a prop can be a difficult chore and one that could require a prop puller -- a device your could either make or borrow. The current edition of "Good Old Boat" has an excellent article on Cutless bearing replacement and details how to make a cutless/propeller removal tool. If your prop is not worth reconditioning, another option is try to find a similar one (blade length and pitch are critically important) at either a consignment store or on eBay. If you buy a used prop, be sure you can return it if it turns out to either in poor condition or doesn't match up with your shaft/engine correctly. The wrong size prop can really overtax your engine. Good luck with this.
Warren M.
s/v "CrewZen" H28.5
Chesapeake Bay
Old 09-01-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Yes. A knowlegable hull cleaner with the proper tools will have little difficulty pulling and reinstalling your prop. It may very well be that your existing prop can be repaired. Look for a prop shop near you for advice. If it turns out you want to replace it, used props can be found at some prop shops or on craigslist or ebay.
In any event, if all you need done is prop work, there is no need to haul the boat.
"Clean bottoms are FastBottoms"
Old 09-01-2008
Karletto's Avatar
Karletto is on a distinguished road
i heard some people just lift the stern up so the propeller is above the waterline. is this true?
Old 09-01-2008
Gary1 is on a distinguished road
Fastbottoms is absolutely right. Popping the prop on a sailboat is not a big deal underwater--if you have the right tools.
As to buying a new one, wait until you have a look at the old one. If all you did was curl the ends or something, a good prop shop can fix you right up, and for a lot less money than a new prop.
Cap'n Gary
Old 09-01-2008
Fstbttms's Avatar
Is it true that you heard this? I'm sure it is.
Is it true that some people do this to change a prop? No.
Old 09-02-2008
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
You might be thinking of a boat hoist called a "Hydro-Hoist" which is a boat cradle mounted on two pontoons. The flooded pontoons are filled with air to lift the boat out. Power-boat owners use them to dry store their boats in the slip so that they have the convenience of a slip and the dry storage so bottom cleaning, zincs and outdrive corrosion is minimized. I don't think you could use a Hydro-Hoist on a sailboat because of the deep draft at the keel; higher displacements and stability when hoisted due to standing rigging, etc.
Old 09-02-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
With advise/instructions from fstbttm and some others here, I changed my prop under water, not once but twice with ease. The key tool is a 3ft length of 2x4 to wedge between the prop, P-bracket and shaft (do not use the engine gear to hold the prop), large hammer, 1_1/4" spanner(for prop nut) and 2- or 3- pronge cheapo bearing extractor(with suitable spanner). Tie everything with cord else it goes to davis jones' locker. You have to use scuba for the job.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 09-02-2008
Fstbttms's Avatar
I know a Merit 25 that lives on a Hydro Hoist. The guy puts garbage bags over the bottom of the rudder and keel to keep those parts clean, since they stay immersed. Seems like a real PITA.
But you're right, I doubt if any sailboat much bigger could be put on it.
Folding Propeller Problems slj145c Gear & Maintenance 4 05-21-2008 08:39 AM
Fixed vs Folding Prop doons60 Gear & Maintenance 11 07-29-2007 08:27 PM
Max prop on a saildrive levenezia Gear & Maintenance 16 09-20-2006 12:07 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
