teak seats - Page 2 - SailNet Community
post #11 of 13 Old 09-03-2008
1970Columbia34's Avatar
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
not sure you really have to when its thickened and tinted black, what will the UV do to solid epoxy? I am asking as I don't know.
1970Columbia34 is offline
post #12 of 13 Old 09-03-2008
Generally turns it yellow and starts to cause it to break down. If it is tinted black, it might not need as much protection, but to be safe, I'd varnish it at a minimum.
sailingdog is offline
post #13 of 13 Old 09-08-2008 Thread Starter
Thanks for the replies. Some of the caulk is missing and the wood is pretty rough. So it looks like I will be removing the caulk. I did not know that you could sand the caulk. I figured it was like rubber? But that would explain how it is perfectly even with the wood unlike the caulk in my shower. Also did not know about taping the bottom so it won't stick to the fiber glass.
So let me make sure I have this right.
1. Stop and buy some rum and cokes
2. remove caulk
3. tape bottom of joint and around the edges
4. caulk
5. get more rum
6. sand wood and caulk until smooth
7. remove tape
8. enjoy
Thanks again,
Randy
Randy
s/v Latest Caper
Beneteau 50
latestcaper is offline
Installed Teak Toerail & Cockpit Seats 1970Columbia34 Gear & Maintenance 10 05-28-2009 05:18 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Homemade Teak Decks, Part Two SailNet Gear and Maintenance Articles 0 10-02-2002 09:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 09:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 08:00 PM
