09-03-2008
If the fuel tank is a permanent one, it should have a vent that vents overboard....usually through a hull-mounted above-waterline through-hull. It should not leak fumes into the boat.
If it is a portable tank, it should be shut when not in use...most small portable tanks have a vent that can be closed.
Fumes should not be escaping into the interior of the boat, unless you've got a leak or are very stupid.
A permanent installation should probably have a fume detector and a fan to vent any fumes overboard.
Originally Posted by KB7EWA
I have a Cal 20 and have been debating between a large electric or a small gas motor. My concern with gas has been fuel storage. I am to understand that fuel is stored inside the boat as long as the vapors can be released? It still seems to me that surely some will escape and poison the crew sleeping aboard.
