12-07-2008
If it clicks only when it is starting a course correction, then it sounds like a relay is the cause of the problem. If the problem is a bad relay in the autopilot, nothing you do is going to change the situation much until you replace the bad relay. Making sure the power and ground lead to the autopilot are twisted to shield them a bit, using ferrite cores and all that is nice and probably should have been done when it was installed, but they're not going to stop a bad relay from creating a big spark—which is the click you're hearing on the radio.
