Cotter Pin - Page 3 - SailNet Community
post #21 of 23 Old 09-05-2008
Owner, Green Bay Packers
John Rousmaniere has also advocated the use of cotter pins over ring-dings elsewhere on sailnet as well. He was not expansive on his reasoning other than he'd had ring-dings fail in some way.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #22 of 23 Old 09-05-2008
Maine Sail's Avatar
Originally Posted by knothead View Post
Still, as I showed in the picture, I use circular rings to lock the turnbuckle and a straight cotter pin for the clevis.
I've used rings for turnbuckles in the exact manner you show and I think that is their best application. I'll try and source some of those larger sizes. None of my local riggers seem to have much of a selection and most use cotter pins. I actually like rings on turnbuckles because it makes tuning the rig faster and your more likely to make the tweaks to your rig mid season that you know you want/need..
I still don't feel comfortable with them on the clevis pins after that Pearson experience and BTW the pin was the right size for the hole. As I said I suspect a slack rig under downwind loads and too long of a pin were also contributing factors...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #23 of 23 Old 09-06-2008
sailboy21's Avatar
I have read in more than one "how to sail around the universe" style book that using a length of 3/32" TIG welding wire, or tapping the hole and screwing in a small machine screw are superior to cotter pins or rings. I haven't tried either of these methods yet.... I have been using a mix if cotter or split rings. It depends on whatever seems to fit the hole "best." The shroud turnbuckles always end up getting a dose if rigging tape, which isn't applied directly to any of the stainless parts so it shouldn't be a problem.
In any event, rings, cotter pins, TIG wire or even nothing at all is superior to those jam-nuts I see every now and then. What a bad idea that was!
sailboy21 is offline
Mast pin for San Juan 23? Pumaman Gear & Maintenance 16 07-30-2008 11:52 PM
fife (pin) rail skookumlady Gear & Maintenance 1 05-29-2006 11:05 PM
Port-Tack Starts Zack Leonard Racing Articles 0 04-07-2002 09:00 PM
pin striping SailAwayToo Gear & Maintenance 4 10-12-2001 07:42 AM
Help! Frozen Pin Removal. Constantin Gear & Maintenance 3 03-14-2001 07:16 AM
