Blogs
User Name
  #11 (permalink)
Old 09-05-2008
Gary1 Gary1 is offline
Gary1 is on a distinguished road
Here be the story on exhaust soot:
The 'wax' you put on your boat is a hydrocarbon compound, in most cases. The soot is also a hydrocarbon, and has an affinity for sticking to other hydrocarbons, so it binds itself to the wax.
Getting it off means using something that will take off not only the black gook on your hull, but the wax, as well, and that leaves the hull unprotected, so you have to apply more wax.
I watched the pros down in Miami fighting this battle on the big battlewagon sport fishers, and one of my buddies found that using a 'natural' carnuba wax helped a bit. The boats still had black exhaust stains, but they washed off using Orpine Boat Soap with wax.
I've tried a dozen different waxes to cure the problem, with no luck. I've also tried some of the whiz-bang polymer polishes that supposedly would stay clean no matter what got on them. So far, I haven't found anything that really works. As for being afraid of polishing your hull because you're wearing the gelcoat out, you're better off polishing with a light polish than scrubbing it down with something strong. Use something like 3M Finesse-it polish, and then follow up with a coat of good wax. My two favorites are Collinite and 3M Marine wax. They're both expensive, but they work in the marine environment. I've tried the other 'name brands', and found that McGuire's, Mothers, Turtle Wax and a couple of others just don't last worth beans.
Cap'n Gary
  #12 (permalink)
Old 09-05-2008
Jotun's Avatar
Jotun Jotun is offline
Space cadet
Jotun is on a distinguished road
I've used the Simple Green as well. It works but I can still see some staining. I have heard of some people inserting a bit of rubber tubing--even a small length of pipe--to move the exhaust outlet about three inches out from the stern, which they claimed helped the problem.
  #13 (permalink)
Old 09-06-2008
midnightsailor's Avatar
midnightsailor midnightsailor is offline
midnightsailor is on a distinguished road
I don't know how to tie into another post yet ,but you might want to read my reply to "cleaning 30 year old gunk off..." in this forum , about 4 threads previous to this one..Rick, SV ARTEMIS
Sponsored Ad
  #14 (permalink)
Old 09-06-2008
philsboat's Avatar
philsboat philsboat is offline
philsboat is on a distinguished road
My friend Don had a sooty behind on his Aloha 28.He fastened a 12" piece of hose to the Exhaust exit fitting(some of them stick out about an inch so you can clamp a hose on)He had a lot less soot after that.
In the Med.we used a product that was a degreaser that worked great.Just spray on and wipe off.Can't remember the name.
s/v Garfield,Mirage 25.
Display Modes
vB code is On
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 07:43 PM
1967 Irwin 37 cc with exhaust problem Irwin37mkIV Irwin 5 08-02-2007 08:03 PM
Black Exhaust Stains On Transom eyebbober Gear & Maintenance 15 10-12-2004 12:15 PM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 08:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 07:55 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
