Old 09-03-2008
EO32's Avatar
EO32 is on a distinguished road
How to deal with exhaust soot on transom?
My canoe back transom is sooty from this year's activity.
It scrubs off some what, but not all the way.
If there is a chemical way to remove the soot, let me know, I tried boat soap. Maybe a degreaser like MEK might work.
I hate to have to use polishing compound since that wears off the gelcoat.
I waxed 6 months ago, but was wondering if there is a good protectant to keep the soot from staining the gelcoat?
BTW: I've got 1700 hrs on my Yanmar and don't notice much smoke.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 09-03-2008
I have same issue and use with great success this: CLICK HERE
apply, wait a minute or two, rinse off, no hard scrubbing just use a cloth.
Hope it helps.
Old 09-03-2008
sailor25b is on a distinguished road
Magic Eraser by Mr Clean. Works wonders on gelcoat. Takes out all scuffs!
Old 09-03-2008
teshannon's Avatar
teshannon has a spectacular aura about teshannon has a spectacular aura about teshannon has a spectacular aura about
I have the same problem on my canoe stern. Unfortunately its on the side away from the finger pier. Soap and long handled brush works pretty well but although I back in it can still be a bear to reach.
Old 09-03-2008
Second the magic eraser. Put a good coat of wax on the area after cleaning though.
Old 09-03-2008
billangiep's Avatar
billangiep is on a distinguished road
This works pretty well....Roll Off Cleaner then spray the problem area with McLube Sailkote Dry Lubricant for Marine Environments
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
Old 09-04-2008
Quickstep192 is on a distinguished road
I've read that Woody Wax does a pretty good job of preventing stuff from sticking to surfaces treated with it. I think the best preventative would be to wash the area after each use. I know that's a pain, but that's what powerboaters do.
Old 09-04-2008
BreakingWind2's Avatar
BreakingWind2 is on a distinguished road
I use a long handled brush and a bottle of Simple Green. Non-toxic, evironmentally friendly and works like a charm.
Old 09-04-2008
harryhoratio's Avatar
Ventilation Guy
harryhoratio is on a distinguished road
Same issue and agree with the suggested removal techniques though have not tried the Mr. Clean pads on the boat but know they work great at home.
Started adding the Sar Brite Startron (I think) treatment to the diesel and it has reduced the smoke and soot on the transom.
Craig Alger
Blog: Sailboatsailor.wordpress.com
Old 09-04-2008
johnshasteen's Avatar
johnshasteen is on a distinguished road
Try Easy-Off oven cleaner - it won't hurt the gelcoat, but if you boat name is painted on, be careful, it will remove the paint. Years ago, I used Easy-Off to take the painted name off Paloma's stern, to replace it with a custom decal and it not only removed the paint, it also removed all the diesel soot.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 06:43 PM
1967 Irwin 37 cc with exhaust problem Irwin37mkIV Irwin 5 08-02-2007 07:03 PM
Black Exhaust Stains On Transom eyebbober Gear & Maintenance 15 10-12-2004 11:15 AM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 07:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
